Check my jacking sequence please
I'm just starting to do my own basic mechanical work - pad changes and flushes. Car is a 2018 Cayman S with the standard four jacking points.
I've purchased 2 Jackpoint jack stands , 2 round top Esco jackstands, and a set of lift pucks. My goal was to get the car up on all 4 without having to jack anywhere but the 4 factory corners. I have done my Googling and YouTubing, but I'm still not 100% clear. Here's what I think is correct. Which side to start on seems arbitrary, but I'll use the right just to keep my description clear.
1. Set parking brake
2. Chock left side tires
3. Lift right rear with Jackpoint puck; right front will also come up
4. Place conventional Esco jack stand under right front lift point with puck inserted
5. Lower right rear onto Jackpoint jack stand
(Right side of car is now up on two stands)
6. Lift left rear with Jackpoint puck also elevating left front
7. Place conventional Esco jack stand under left front with puck
8. Lower left rear onto Jackpoint jack stand
9. Gentle rock to make sure everything stable.
Is this OK? The part I'm unclear about is step 6. With the right side of the car up, is it safe to jack at the left rear? The left front will be transiently unsupported and need to be lifted an inch or so above level to get a jackstand under it.
Anything else I'm missing? (I will use pads under jack stands to avoid denting hot asphalt).
wingless (06-04-2023)
Received 1,794 Likes
I have not used jack stands since a horrific paddock accident I saw at The Glen a few years back involving jack stands. That’s just me. I’m not saying not to use them. Just my preference after seeing what I saw.
Safety first always….
How are you getting the rear jackstand under the rear jack point since its on the jack? Are you using the frame? I normally do each side at a time when I change wheels, rotors or pads. I place a jack stand under the rear suspension for safety. If I put on all four jack stands, do the front as you describe. Lower the car on the front jack point and then jack from rear engine pan cross brace. Placing two short stacked 2 x 4s under the rear tire helps with stability. You can buy an after market rear jack point, but they are $100.
My only reason to do four jack stands was a brake flush. Got to be too much work. Now I pay every six months for new Motul 660 which I supply since I track my 2013 Boxster S.
Since you are DIY you might consider brake caliper studs. If you are not tracking the frequency of rotor replacement and front pads (have to remove the caliper) won't be that often. Porsche recommends new brake caliper bolts each time for corrosion. The opportunity to damage the aluminum threads exists every time.
https://jackpointjackstands.com/
They are different than standard jack stands and allow you to replace the jack as a lift point. I don't want to jack anywhere on the frame or install one of the aftermarket rear center jack points..
I agree re jacking one side at a time for tire and pad changes, but I also want to do my own flushes with all four up; I'm also a Motul 660 fan. I am tracking 20+ days a year (that's why I posted in this forum) and pads and fluid will be frequent. If I were just street driving, I'd just pay an indy to do all this every couple of years.
I have front caliper studs (Tarret), prior to them I did use new bolts every time.
Anyone here with Jackpoint familiarity that can verify my sequence?
Apologizes. The "Jackpoint" brand did not register. Fantastic produce. If I were still doing my own flushes would most likely have a set. You and Jay Leno.
Where and what do you track?
No apology necessary! I'm halfway between NJMP and Pocono but I prefer the former, especially Lightning. I also get to the Glen and Summit, hoping to hit mid-Ohio and VIR this year.
Car is a 2018 Cayman S with track wheels/ tires, minor suspension work and brake upgrades. For now.
Happy to have you.
I think your sequence makes sense. Have you tried your JackPoint stands yet? I have a pair and they're an ingenious product, but I ran into clearance issues with them with my GT4. Even though I use a low-profile aluminum "racing" jack, and I bought the specific low-profile aluminum discs/pads from JackPoint, there wasn't enough clearance to get the jack and disc combo under the car to start the lifting process. So if I was jacking the passenger rear, I would have to start with the passenger front with a second jack and lift that whole side a bit to get enough clearance to get the first jack and JackPoint disc under the passenger rear jacking point. My GT4 track setup was on 19" Forgelines, so the car sat lower than stock--your Cayman S might have adequate clearance, but this is a workaround if you have the same issue. Where the JackPoint stands were a huge help was when my wife's BMW 3 series had a screw in the tire last summer. I was able to quickly get a JackPoint stand under the affected corner of the car, remove the wheel/tire, and let the car sit safely on the stand in our driveway while I took the wheel and tire to a local tire shop to get repaired.
Another thing to strongly consider, given your frequency of tracking and planned maintenance, is a QuickJack system. People rave about it. Probably the best $1300 you can spend, and it will easily pay for itself with your DIY labor cost savings.
I know this doesn't answer your question but quickjack and catalyst (from your other thread) have been the two purchases I've been happiest with since starting HPDE.
I'll second the QuickJack, it was a game changer for me, I haven't touched my stupid jack stands in months, that and the simplest thing, the Milwaukee lithium battery impact, I never go anywhere without it now.
Personally I'd prefer to jack one end of the car and put two jackstands under before repositioning the jack. I wouldn't feel comfortable with a car in the air supported by one jackstand and a jack. Probably OK 98% of the time, but it's the 2% I'd worry about.
