People who overstate their driving ability. The reality of correcting oversteer.
#61
I suppose just about any oversteer is technically saveable if you can beat the car's rotation rate with your steering before you hit max lock.. I've talked to drift car guys that use fast racks with extra steering angle to make it easier.
There is a trick that may help if you notice your steering isn't fast enough though. If you use throttle combined with hard brakes you can lock up your fronts while the engine power counteracts rear brakes to keeps the rear tires rolling. This can save you from a seemingly unsaveable spin at the cost of possibly flat spotting your fronts. I remember seeing a video of an F1 driver doing this. I want to say it was Mark Webber, but I'm not positive. I'll see if I can find the video.
#62
its not the handle bars "breaking loose" its the entire instability of the motorcycle , front and rear, out of sync. it's very analogous to pilot induced oscillation (plane bouncing up and down on a landing approach).
#63
#64
Found a video of Max Verstappen doing the throttle+ brake save. It's at 2 min. It's in the rain so works really well and no flat spots.
https://www.youtube.com/watch?v=IOq1NZ-7eSI
If you are talking about this, it is a very specific type of save.. basically both feet in, and wait it out.. the dynamics is that the front that would normally allow for the rear to come around, gets locked up and washes out forward, taking the rear momentum component out of equation. many times this helps (both feet in at a point of not being able to save through correction) from completing a spin . the best way is to have the steering input keep from getting to that point by matching the rear of the car's movement.
#65
Here's a little drift I did through turn seven at Sears Point. Completely unintentional but by that point in the event the Hoosiers were overheating. It was in excess of 120 degrees that day. It's all about practice on the skid pad and applying that knowledge in safe corners.
#66
Topical thread. We're taking a bunch of guys ice racing this friday
If you don't have ice or snow covered back roads (with runoff) then +993 for rally school.
#68
https://youtu.be/yYrauZb7wCk
#69
#70
He knew that if he kept it opposite locked, the car would pendulum the other way?
#71
actually, at that point, when locked , there is not much the wheels being angled can or will do. however, feeling the reduction of front grip being locked, allows the rear end to catch up , straightening the wheels before the chassis is pointed straight, allows for an instant recovery (by brake release) when the car ends up being pointed straight..... (easier than timing it) however, if the front wheels were rolling, this would be a different set of conditions.
#73
View some old videos of the Ayrton Senna's racing in the rain. At the speed he was going, he absolutely drove his car to the limit....and his car control of recovery is miles ahead of everybody during that era.
#75
3) hand brake turns
