KMP paddle shift kit
I believe that this system is designed for Sequential Gearboxes, so you would have to also install a sequential gearbox too.
All of this is possible, it just costs $$$$$$$$ and you are probably better off bying a 997 Cup. That is unless your 996 is an RS or RSR with sequential....
Basic Site Sponsor
Basic Site Sponsor
Received 3,237 Likes
Life?
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
KMP paddle shift is made for 997 sequential gearbox, there is an air jack blipper but no clutch management, so you need to use the clutch for downshift.
One car in our club races series is running with the kMP , the guy had a gearbox rebuild after 4 hours racing but I don't know if it was time or not to do this. I'm waiting for more races to have an opinion.
It seems there is an other manufacturer in GB but they have problems to work with the BOSCH 3.1 ECU up to now.
Former Vendor
Sent: Wednesday, December 12, 2012 5:02 AM
To: Steven Goldman
Subject: Re: i gues the question is...how does one need to activate the clutch on downshifts?
It is clutchless downshifting. You only use clutch when you drive off.
Verzonden vanaf mijn BlackBerry®-toestel
________________________________________
We use KMP Products and their shift kits alot and they are fantastic.. They interface with the Bosch ECU and all the existing sensors and load cells in the stock system so with the flick of a switch you can go back and forth between paddle shift and stick shift (handy for those running cars in classes that dont allow paddles but also want to run in open classes ) . most of our cars are doing 12 and 24 hour races with gearbox builds before and after so we really do pay attention and notice the difference in regards to gearbox wear on the dogs and claw collars... the KMP shifter more than halved our wear rate...... so very happy! They also have the Motorsport Adjustable ABS systems available which are fantastic!!
Great customer support and easy to deal with...
Our team in uk have used both system and I'm told the
http://www.shiftec.com/
System is the best ..!
http://www.lapengineering.com/
Call lee penn above and say I sent you ...he's really good and is a dealer for the system and motec..! He will sort you out
Your tranny wear will be better with the KMP paddle shifter as it eliminates half hearted shifting and really synchronises the shift cut better than doing it manually.. not sure about the other systems..
