broken CV boot
Adam, I changed over the grease that came with a black axle from you, to Krytox. After 20 hrs, that grease was shot! It was the consistency of syrup. I switched to the GPL 215
Is the 215 ok for axle use?
I originally wanted to take them apart periodically and repack. But, since the outer ends can't be disassembled, and Krytox is not soluble, I've just added grease to them.
215 is marginally adequate for Cup cars (with consistent maintenance), as long as you don't run tracks that are excessively fast or have the car very low. I believe 215 is what comes in the black cup axles. If you plan to go to Daytona, definitely use 217.
I expect you will be fine with adding grease to the outer joint, as I expect you do not have the proper tools (as described) to disassemble the outers.
Will take my Cup to TRG next week to get the CV boot fixed. Wonder if this is an easy DIY. TRG quoted 1.5 hours of labor. Should be just loosen the 6 bolts, unclamp the boot and slide it out along with CV joint then repack with the toxic Krytox brew?
