Portable impact wrench options
Change tires can be a PITA with my CL wheel. I am looking for an impact wrench that can quickly take the center lock on and off much like what race team use. The center lock spec on my Cup is about 340 ft lbs. I found some portable impact wrench made by Milwaukee and they offer torque from 325 ft lbs to 450 ft lbs. Any suggestions?
You have a nitrogen tank? Use one of these: http://www.brunnhoelzl.com/impact_guns.html
You have a nitrogen tank? Use on of these: http://www.brunnhoelzl.com/impact_guns.html
Welding supply house and probably other industrial supply places as well. I think the nitrogen tank pressures are a few thousand psi, which is why you need a decent regulator to give you easy access to much higher pressure than the air tank will usually provide. Do you have the wand for the air jacks on your car? What is the pressure supply requirement to get the car off the ground?
I think you're going to be very hard pressed to find a battery powered impact that has that much true torque. My previous monster could do about 1-2 400 ft lb removals and then it would be worthless. You really need air for that.
Man ... air tank it is. Just hope they are not monster huge
GT3 player par excellence
You could always break them free and set final torque with a big wench and use an electric go get them off and on "most of the way".
Guys with air... You really using THAT much? Sheesh, how many trips to the airgas salesman are you making a year?!
If you're thinking of only using 1 tank then definitely get the large 300 cu.ft. tank. Yes it's a heavy mother, but I can lift it in-n-out of my trailer or run it in with a dolly and I'm only 155 lbs. and 62 years old....
PS: A POC friend plumbed a single tank to operate 2 regs simultaneously, one for HP, one for low. He keeps it permanetly on a dolly strapped into his trailer and wheels it out at the track. Me I prefer the 2 tanks as they last longer (duh!) and I really hate loading and unloading the heavy bastards. I even keep a smaller (200?) tank and reg. in my garage at home....
I am 165 lbs and ... feel like 85 years old most of the time lol. Thanks for the great advice JR. I went to airgas today and their largest 5' tall nitro tank run $300 to purchase then $30 to exchange the tank. I have an open trailer so I have to figure some ways to lay tank flat for transport and dolly around while on track. I can charge 50 cents for balloons ... wait, that's helium
I think it might be easier to just leave in the back of your truck at an event. Unfortunately you need 350+ lbs. of pressure to lift the car so you're sort of stuck with a N-tank....
Important safety note: Never, ever transport a nitrogen tank without first removing the regulator and screwing the heavy steel cap back on. First off it's illegal, more importantly it's dangerous. 2,000 lbs of pressure can make a deadly projectile out of that tank.....
The open trailer certainly presents some logistical challenges.
