Cup car sequeantial gear down shifting
that's too funny mike. i totally agree with you how porsche motosports does business. if you are stock holder it's brilliant but if you are receiving end it's painful. don't get me started with saga i had to go through with porsche motorsports to get my motec upgraded and running. lol
Since Xeviuu's question was answered, why is it that you need to use the clutch on downshifts when it isn't required on upshifts? When compared to other sequential (Ferrari comes to mind) boxes it isn't required nor possible to use a clutch.
Is there any benefit from the Porsche box?
The advantage of the gearbox is with the no lift shifts every shift is about .01 quicker. At VIR where you upshift about 12-15 times throughout the track that is .15 quicker just from shifting. Also the driveline loss on this transmission is less. So more power to teh ground.
I also noticed in the video he left his hand on the shifter for the long straight up shifts. I thought there was a pressure sensor on the shifter and this was a no no?
Does the Manthey throttle control do the blip for you or does it make sure it is an adequate amount of throttle?
Guys , I have the trottle control on my Cup car , it's great because you can use your mind only to braking ...and locking ..BUT .....it's so easy to do some gear mistakes : you MUST sincronyze the clutch and the gear level movement ...if not it's easier to do some damages on clutch and gears ..
6th Gear
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Does anybody down shift the 997 cup without the clutch? I assume this is a dogbox type sequential. The Hewland sequential in my pro-mazda is pretty easy to down shift without the clutch once you get the timing of the lever and the blip down. If I have to go down more than a single gear, I use the clutch. Single down change corners are smoother clutchless in my car. I don't see anyone talking about this technique with the cups. Just curious.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I was checking out the video and while loving the data overlay and foot work cam, I noticed it was taken from Sugo -- we've tested there and its a NARROW track!
http://www.youtube.com/watch?v=NZeoFEK1yzk
Mike,
the strain gauge sensor is only active above 2800RPM and benefits upshift. There is a fully active clutchless paddle shift system avail. for these cars, clutchless up and down shifts, which tremendously reduces wear, but is illegal in most classes.
Bernie
Bernie
