Pirelli DH - are they directional?
As the title asks. First time using DH and wondering if I can rotate them care free. Hankook F200 I have used previously are directional (which I found quite surprising). Is this also the case with the Pirellis?
Secondary question, do people balance the wheels after fitting slicks? It is my understanding that they rotate on the rim anyhow but I’ve always found not balancing to be horrible for vibration on track! More so front, rears not really an issue.
If anyone can chime in on how to figure the DH date codes it would be of help to me. PCA Club Racing rules require the yellow bar code label outboard and the red inside from what I've read. . . .
https://pcaclubracing.org/wp-content...acing-2020.pdf
I've never had a problem with Pirellis rotating on the rim - only with something like a Hoosier. Always balance them and tape over the weights with heat reflective tape. You'll also need to clean out the rubber debris regularly (especially on the front wheels) as you will accumulate quite a bit that will throw them out of balance also.
Francesco996 (03-31-2021)
My Pirellis will clock on the rear so I use EuroPaste Tire Lube as recommended by someone at Pirelli who mounts a lot of tires. I just bring it with me to wherever I'm having them mounted.
Bob
Bob
From PCA 2021 rule change notice
GTC3 (996)
There is no longer a spec tire for these cars. Rims must stay the same, but tires are free (same as GTC1 and 2).Rich
You should be fine rotating... I've done it but never during an event that was timed, just for testing... but times showed to be very similar with likely only change being track conditions, etc.
The the Pirelli will 110% rotate. I still balance them, sometimes just the wheel or wheel with fresh tire mounted.
Once they do a full 360º they self balance themselves! Just have to deal with a few laps of vibration! hahaha
I am going to try euro paste this year as someone mentioned above.
