Porsche Cup Cars
Sponsored by: Race Cars For You
how to load/secure a 991.1 cup in a trailer?
Old 10-19-2020 | 04:14 PM
MarcD147's Avatar
MarcD147
Default how to load/secure a 991.1 cup in a trailer?
the car has a very flat bottom and wouldnt want to remove bottom panels for loading.
what is the best way to secure it? I used axel straps this weekend through the wheels but it seems very sub optimal and not feasible at all until the car has cooled down.
car is pretty wide so getting D rings to fit the wheel bolts are not feasible unless I put some 2x10 down so I can clear the trailer wheels
my trailer is an 24' ATC
Old 10-19-2020 | 09:29 PM
hollmatt's Avatar
hollmatt
Heh Marc, i bought my 991.1 Cup in July and i'm loving it - i have a Trailex Enclosed trailer and i started with tie down straps with tie down hooks that connected into the jack points front and rear. The previous owner had open trailer but in an enclosed trailer with limited access this is a pain and a 2 man job so i had my shop install tie downs underneath the car. They fit on the front jack points and on the rear sub frame and this is much much easier. Its still a little tight getting under as these cars are low so I did get an exhaust burn scar after loading the car when it was still warm... I also winch my car on as the clutch is more on and off, i can drive it off ok though as that's easier. PM me if you want to compare notes. Bummer about your old car as i was there for the PCA race last year and saw the carnage.
carbondan (10-31-2021)
Old 10-20-2020 | 02:58 AM
Francesco996's Avatar
Francesco996
Do these hooks not exist anymore for the newer cups?
Old 10-20-2020 | 08:35 AM
Phokaioglaukos's Avatar
Phokaioglaukos
Having a hard time visualising this. By wheel bolts, do you mean transportation rings that fit under the wheel nut? That's what I use with tie downs to D-rings in the trailer floor. There is not much of an angle to the tie down straps off the longitudinal centreline, but the car does NOT move sideways on the aluminum tread plate over rubber coin flooring.
Old 10-20-2020 | 10:04 AM
Dan Jacobs's Avatar
Dan Jacobs
Tire straps through the wheels works for me
Old 10-20-2020 | 10:07 AM
MarcD147's Avatar
MarcD147
@Phokaioglaukos yes transportation rings is the proper term, and @Francesco996 yes I assume they still sell them.
problem is car is too wide for them to fit in enclosed ATC 24 as the rings would hit the wheel wells of the trailer. so that is why I was thinking putting in 2 2"x10"x10' planks so the car sits high enough to clear them
I will investigate the tiedown suggestion by @hollmatt
Old 10-20-2020 | 10:13 AM
Phokaioglaukos
Now that I understand, I think I would use the planks as you suggest. I doubt the car would move around on them and if you cut an angled ramp on the ends of the planks it should be smooth. It's just not an issue in my trailer and I'm surprised it is in yours.
Old 10-20-2020 | 11:41 AM
THJR's Avatar
THJR
I'm running just a 24x8 CarMate and with transport rings on the car fit perfectly. Bone stock trailer and car, rings clear inner fenders no problem.
2x12 risers I used in the last trailer but it was just so annoying having those things on the floor all the time... plus with how that trailer was set up, to get the load evenly distributed the beaver tail cause some issues when installing the boards. never again...
Tie straps through the wheels work fine but don't hold the car as well. On bumpy roads they'd almost always have some slack in 'em, with the tie down rings the car doesn't move at all.
Im also a tad ODC and after my final pre-race alignment/corner balance I'd hate to knock something out just a tiny bit putting straps through the wheels.
FWIW Im thinking about selling my to get into a larger rig that can haul 2 cars and all gear.
Great trailer for the money but I should've just bought the gooseneck right out of the gate.
Its a 2020 with just the njmp and summit race on it... so ~520 miles from new. Winch with wireless controller.
Old 10-20-2020 | 02:52 PM
DDun911's Avatar
DDun911
I have hooks mounted under the car , previous owner had installed. I will post a picture once I get by the car again. Makes life very easy.
Old 10-20-2020 | 04:53 PM
Francesco996
Lucky me: my new trailer is 2.16m wide inside, should be enough for upcoming cars I hope....
But a bit of pain to drive with, especially in my backyard with 2.3m overall width
Old 10-20-2020 | 06:03 PM
Q&A's Avatar
Q&A
I would not rely on the 996 Cup center lock rings / with tie-down hook.
The overlap is soo little. Emergency braking and one might disconnect.
I am doing it this way: I wrap the tie-down around he axle part of the wheel.
There are other ways too, but i figured this is a safe way that is also mild to your alignment.
Old 10-20-2020 | 06:51 PM
Francesco996
That's not really working with the old BBS wheels.........never had any problems with the center hooks, I usually tighten them to 200 Nm
Old 10-20-2020 | 07:11 PM
DDun911's Avatar
DDun911
https://www.rennline.com/Tie-Downs/products/1637/
This is what I have, works great.
Old 10-20-2020 | 10:04 PM
awew911's Avatar
awew911
I have long Macs Axle straps that go through the wheels (once cool) and then I cross the tie down straps.
Take 5 minutes to tie it down. Use a winch to pull it into the trailer and get a remote (lots of inexpensive retro kits to make non-remote winches "remote").
Just finished towing back from VIR to Jacksonville (8+ Hours). No issues. ATC Quest CH305 24'.
Old 10-21-2020 | 03:16 AM
Francesco996
Sometimes I load my car into the trailer a couple minutes after last practice (when I want to get home asap), so quite hot.......
These ATC trailers are huge, I don't even think 102" width is even legal in Europe, but these wheel arches killing the space
That's the other option with some wheels (my ex TT)
Quick Reply: how to load/secure a 991.1 cup in a trailer?
