Transmission fluid leak and transmission failure
I have a 2005 Cayenne S in great physical condition with 80K on it (automatic). A month ago, I had a coolant leak, and had to change the plastic coolant pipes to aluminum. Also changed the starter, serpentine belt, 20K service and 2 break pads/rotors for a total of $4,000.
Last week I noticed another leak. Now the repair shop tells me that it was transmission fluid and that the seal needs to be replaced. They also said something about the stator and quoted around $2,500 for the job. But the added that this type of problem usually happens because there is something wrong with the transmission, so if I fix the seal and stator, the transmission could still fail at any time. Is it possible that the new transmission issues are connected to the repairs I did a month ago? To rebuild the transmission would cost around $5,500.
However, the guy said that if I could keep refilling the leaked transmission fluid, then I could probably drive it a while longer without any repairs. But he said there is no way for me to add transmission fluid myself. Is this true? How difficult is it?
Also, what do you guys think I should do? If I spend the $5,500 to rebuild the transmission, what other large repairs could surprise me next? If I could drive the car for another two years, without additional repair costs, and then sell a working car, I would do the repair.
Any input and advice would be greatly appreciated.
They are feeding you a load of dookie and generally bad advice. You will find from reading on this board that it is very common for the transmission seal to leak after coolant has spilled on it for a while. Especially if the people who replace the pipes are careless in the process and let a bunch more coolant spill down onto the transmission when doing this service. Rarely does the transmission fail unless you drove it low on fluid for a long time. The leak is a documented result of the coolant.
It is difficult to add transmission fluid the first time, but once you know the process and have the right tools, it is absolutely a DIY thing that most anybody can do.
DO NOT rebuild the transmission. Just get the seal replaced, and not by these fools that did your previous work. It is a porsche, so there is no telling what the next repair or cost could be if you don't do any of the work yourself, but you are in the right place if you are motivated to try!
Here is the procedure for changing tranny fluid and filter. http://www.pelicanparts.com/techarti...ter_Change.htm
You can see how to top it up from this. I had the torque converter seal leak and had to top up the fluid every 3 weeks. A bit of a pain, but not too bad. I did trade it in so I never fixed it.
Thanks nodoors for your reply. Unfortunately I don't know much about the inner workings of cars, and I've never done any DIY. Can you point me to a video showing how to add the transmission fluid?
And if I would replace the seal, what about the stator that they said could also be damaged (but they wouldn't know until they replaced the seal)? How much should something like this cost?
So you're saying that the transmission is most likely OK, and that replacing the seal (and maybe the stator too) would be enough? I was told that if I replaced the seal and stator for $2,500, then later I could have to spend another $5,500 to rebuild the transmission. But if I rebuild the transmission now, I "only" have to pay $5,500 including the seal and stator.
Can anyone recommend a good shop in the Los Angeles area that would replace the seal for less? But the shop I use now has always given me fair pricing, as far as I know.
Talk to Tony Callas at Callas-Rennsport
From when the car was new up until 5 years ago, I always had it serviced at the Porsche service center in LA. When I switched to the current shop, they charged me less than half of what Porsche charged for things like breaks and 20K service etc. So I assumed that the price difference would be similar for other jobs too. And I have had no complaints until recently when these two big issues have arisen (coolant pipes and transmission seal). But these things seem to be expensive to repair anywhere?
A trustworthy shop would have warned you of the impeding doom of the plastic coolant pipes along with the expensive carnage that happens when they fail. Drive until one bursts and the starter and torque converter seal are automatically done. Then you have those who continue to drive with the engine overheating which can't help when it comes to the cylinder scoring issues.
As far as the stator??? That's the stationary windings in something like your alternator or starter motor. You mentioned they already replaced the starter and I have no idea why they would be going after your alternator (or even refer to an alternator as a stator).
Thanks a lot guys for your helpful input! I feel more confident now that there is nothing wrong with my transmission (and I have never had any problems with the shifting). So on Monday, even if it hurts economically, I will probably go ahead and order the $2,500 job to replace the transmission seal. Hopefully this issue was all because of the coolant leak, and everything else is fine. If I can drive for another couple of years without any other major repairs, it will be worth it.
After speaking with the shop again today, to clarify, they said that if they start the job and the stator is ok, then everything should be fine and there is no need to rebuild the transmission. But if the stator is damaged, which they say they have seen in the past, then I would have to do that. The reason being, if I remember correctly, that no-one could not give any warranty on a stator replacement without a transmission rebuild.
If they are referring to the torque convertor as the stator, the only reason it would need to be replaced is if they damage it when they pull the transmission to replace the seal. The torque convertors on these things almost never break.
Thanks for all your help! I really appreciate it!
I am not going to be surprised if they happen to think it needs the full transmission rebuild once they have your car in pieces at their shop. I would beware of this shop as they clearly don't know the Cayenne very well from what you have described, but it is your car and money. Good luck and let us know how it goes. :-)
I heard the same BS when the trans/differential seal failed on my 04CS at 60 mph. Lost both drive and reverse, had it towed to the closest indy shop.
They replaced the seal and refilled the trans with genuine Porshce trans fluid at $100/qt. They absolutely refused to use anything but P fluid. During a test drive they thought they heard cavitation sounds with a stethoscope and insisted the trans must be flushed.
Refusing to continue with this robbery they required that I sign a waiver voiding any guarantee for the repair work.
After another 40K mi. it was sold without another trans issue.
If the transmission is functioning as expected save your $$ and have the seal replaced. Forget anything else they try to sell you.
