Sources for 100-cell race cats??
Hey guys. I've searched online and I can't seem to find a source for these race cats seperately other than at FVD. A bunch of sites refer to them as German made race cats so I assume there is a manufacturer somewhere over there. I only need the convertor itself and maybe the transition cones.
Does anyone know the manufacturer of these parts or will I have to pay $500 each to get em from FVD?
Thanks,
Thanks,
May seem kind of off the wall, but...
I just got a new "Jegs" catalog and they have bare (weld in) sport / race cats marketed by Dynatech listed that look very similar (4" Dia, 11.5" long)similar to the ones used by Cargraphic for the 993's. $150 a pop., three different pipe diameters, 2.25, 2.5 or 3"
Hope the info helps.
No knock on the hot-rod lovin,' nitromethane snortin' folks at JEGS, but I believe there really IS an internal difference between a $500 Cargraphic or FVD cat and a knockoff. I would try to find a good used set of 100-cell Euro cats on eBay before I went the Hot Import Nights route with a new $150 part.
Lee in D.C.
Lee in D.C.
If both cats are foil based then there probaly isn't much of an issue. The grade used in an Alfa-4 type and will work the same. Probably rolled to 0.0015" which gives it a smaller cross section than a ceramic monolyth.
On the other hand, if either happens to be ceramic I wouldn't touch it.
RL Technical Advisor
Princeton:
Just a word to the wise,...![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Most of these 100 cell cats do not "catalyze" well enough and OBD-II cars can throw a secondary oxysensor out-of-range range code.
Caveat Emptor on those things.
Originally posted by Steve Weiner-Rennsport Systems
Princeton:
Princeton:
Steve,
What happens if the cats are removed completely? I've heard a few say that the car needs some backpressure. Also that the stock cats aren't too restrictive.
Thanks,
Thanks,
Hi Alan:
Removing the cats on naturally aspirated 993's reduces overall power, especialy below 5000 RPM.
They are VERY well done and in fact, the 993 Cup cars had stock HE's, cats, and no mufflers. That setup also kills low RPM torque, but adds a tad more high RPM HP and it didn't matter for competition anyway,....
