Lowering While Parked Without a Lowering Module
I want to share a little project I've been planning and finally implemented yesterday in case others are interested in doing something similar. For starters, I have a 2018 Panamera Turbo Sport Turismo (so, 971).
So, I've been wanting to come up with some way of lowering my car when parked. I don't care so much about lowering it while driving; no one really sees your wheel gap while driving. However, the lowering modules are still stupid expensive (if anyone has a good used one for sale, lmk), so I didn't want to go that route. So, here's the scheme I devised:
Install lowering links to lower the default heights, then use the drive modes to allow me to ride and park at my desired heights (or at least closer to them). I lowered all corners by about 30mm. So, now my Medium height is the same height (or a smidge lower) than the OEM Low height. I've set my Individual drive mode to: medium height, exhaust open (performance exhaust), start/stop off (of course), and sport suspension. However, I have my default height set to Low. In case you weren't aware, the car will park/settle into the default height setting, regardless of the drive mode it's in when you turn it off. So, I took advantage of that... Individual drive mode allows me to drive at my previous Low height, but as soon as I park, it will settle to the new default Low height (about 30mm lower than before). I could lower it a bit more, but I wanted to leave some margin (err gap) for error in the event I forget to put it into Individual mode while driving.
My wife can absolutely not see the before/after difference, but she also still refers to my wheels as "hubs," so... Check out the before (top)/after (bottom) pics... not a huge difference, but can definitely tell, especially in person.
FWIW, I used Airmatic lowering links, which were easy to install (definitely requires precision measurement, but otherwise easy). Happy to share direct link if interested.
P.S. I do realize the rear gap is greater than the front, but so was OEM... so, kept the "tilt" figuring the engineers at Porsche did that for a reason.
I like your thought process here and can definitely see the before/after change. Ride height and quality unchanged, with the added bonus of looking low while parked. 👍
healthnut76 (07-18-2022)
I have noticed when I park on a slight incline the car will self level and it could be the front or the rear that is higher.
healthnut76 (07-19-2022)
https://www.airmatic-lowering-links....-lowering-kit/
Yes, our cars will definitely attempt to self-level, but the back is definitely higher than the front on flat ground... at least on mine.
Chimuel (07-20-2022)
But, doesn't it return to your default height setting when parked and off? My adjustments have dropped it another 30mm beyond the lowest OEM setting.
The following 2 users liked this post by DogWood:
healthnut76 (07-22-2022),
Unnamed335 (07-22-2022)
healthnut76 (08-16-2022)
