Just got my 2022 Macan GTS. Wanting to install my radar detector w/ a Mirror Tap harness I searched forums and the internet for a how-to. Surprisingly I found zero information about using a Mirror Tap on the Macan. Seems most people were running a harness down to the fusebox, which seems like a huge PITA. Having installed Mirror Taps in other Porsches (and other makes) I have owned I was pretty sure it was possible. So I tackled the project and took photos, hopefully this will help others. As far as I know all Macan generations should be the same.
1.) You must remove these 3 panels in the order they are numbered 1-2-3. Reinstallation is the reverse order of removal 3-2-1. Tip the mirror all the way down to maximize clearance.
2.) The center panel w/ the passenger airbag light can be easily removed by just putting your fingernails on either side and carefully pulling downwards. (Ignore that the main panel is already removed, I took this photo out of sequence).
IMPORTANT: DO NOT UNPLUG THE CONNECTOR FROM THE BACK OF THE PASSENGER AIRBAG LIGHT - Just let it hang. If you unplug it you could get an Airbag fault. If you do it's not the end of the world, you can just have the dealer clear the fault code and reset the airbag light, but it's avoidable.
3.) Remove the rear view mirror ball stalk cover. This piece is in two halves. There is a small opening on the forward seam you can insert a nylon pry tool and twist. This takes a bit of effort, be careful, but it's not hard. Importantly you want to take off the passenger's side first, then the drivers, due to the way the tabs are oriented to avoid breaking them. Reinstallation is the reverse of removal....put the driver's side on first then snap the passenger's side into it. Remember you must have the center panel w/ the airbag light off in order to get the stalk cover off/on b/c it goes underneath it at the back edge.
4.) Remove the main roof console panel bezel by starting at the windshield end and gently pulling downwards with your fingers. Work your way backwards separating the tabs. This was very easy to pop off, just be careful not to bend the bezel as you work your way around.
5.) Now for the tricky part. Getting the main roof console panel down. I saw lots of posts about removing this on Cayenne forums and everyone seems to manhandle it and bend the metal clips. You can get it off without any bending or damage. With a thin nylon pry tool slide up between the panel and the headliner and push the clips in as you work the panel downwards. These little indentations I am pointing to correspond to each metal clip.
6.) This shows where you are trying to put the thin nylon pry tool. The main roof console panel is hinged at the front, so start at the rear/center and progressively release each clip w/ one hand and the pry tool while using the other hand to keep downward tension on the panel. Once you get the first 2 clips the rest is easy b/c you can now see each clip.
7.) The main roof console panel is hinged at the front. Once all the clips are released it will hinge forward. You can lift the hinge tabs out of the cradles to free the center panel once it's rotated down and forward.
8.) Let the main roof console panel and the center airbag light panel hang by the wiring harnesses, they are not heavy. The connector you want to tap into is the BLUE connector. This is the connector for the rear view mirror.
9.) Pull the blue connector out of it's holder.
The wires are as follows (at least on my 2022 Macan GTS, Porsche may have changed wire colors on different years/models as they often do, so check w/ a multi-meter):
Mirror side of connector: Blue +12v switched / Red +7.5V - variable, assume this is for the auto-dimming / Brown Ground
Vehicle side of connector: Red-blue stripe +12v switched / Black-yellow stripe +7.5v variable / Brown Ground
10.) I chose to tap into the mirror side of the connector b/c that was the side I was going to run the MirrorTap harness out to where I wanted to mount my radar detector.
Tap was to the blue wire for +12v switched power and brown for ground. After putting the taps into the connector I zip tied the MirrorTap harness in place so it would not pull out and snapped the blue connector back into it's holder.
11.) Prior to closing things up I tested to make sure the power was good and it went on/off with the ignition.
12.) When reinstalling the main roof console panel make sure you get the hinges back into palace first, then rotate the main roof console back into place.
13.) Everything back together w/ the Mirror Tap routed out between the middle airbag light panel and the main roof console.
14.) Mounted the detector w/ stick on mount in position as high/close as I could get it into the designated "toll pass" area for those of us with Thermally and Sound Insulated glass option, where electronic signals are supposed to be able to pass through.
15.) I also chose this mounting position so that I can use my sunshade w/o interference. I tried a Blendmount I had left from my GT4 (same mirror stalk) and it hangs down too low for the sunshade (plus not a good spot if you have the insulated glass option).
All done! Hope this helps someone. I was surprised the Macan has been around for coming up on a decade and there is almost no info on the interwebs about using a MirrorTap that I could find. Cheers!!
my main panel with all the lights and buttons isn’t snapping back in, and hovering a few inches below. Is there a trick to get the clips to hold it back up?
Thanks for this write up. Worked great on our 2023 GTS. The clips are a complete pain in the @$$. I was able to get right side out clean, but the left ended up hanging on and getting bent 90 degrees on the way out despite my best efforts. O well, bent it back and it went back in no problem.
Great and detailed instructions. In step 10, do you have photos of the actual "taps" that you made into the blue and brown wires? I am not sure of what I am seeing in your photo. Also photos of the tap itself prior to the installation. Alternatively, does anyone have instructions for using Add-a-circuit into the fuse box? Greatly appreciated.
Just completed installing a mirror tap following these instructions in a 2023 S. All the trim and module pieces came out easily and the wiring was simple. Thank you for sharing this.
This is a very detailed, helpful post. Thank you for sharing. That being said, it is much simpler, with no risk of damage, to pop the left fuse panel cover off, locate a switched fuse or blank switched opening, and run the cable from the box to the outside weather gasket and then across the A-pillar cover to the gap between the windshield and headliner. I have used this method on two Q5s and my current Macan to mount my V1/V2. I also did the same on the right hand side for my dash cam (just in the Macan - the Q5 has no fuses on the right). Piece of cake. Several posts using this method. No disrespect intended.
Anybody use FitDVR? Nice little unit so that you do not have to run wires all through your headliner and A pillar to hardwire to your fusebox. Unobtrusive. Thinking of using for dashcam in my Macan. Here is a vid of it.
Removing the overhead panels looks just to scary for me. I routed mine under the weather gaskets etc. Piece of case and no potential damage. But that's just me...
