How To - Macan Mirror Tap for Radar Detector
Nickshu (06-25-2022)
So far the standard Uniden suction cups hold well. I put them as high as I could right up to the headliner. I do worry a bit but if it were to detach, the cable will probably hold it or slow it down. Eventually I will probably change to one of those taped mounts posted earlier.
Thanks to this excellent write up, I installed mine today. It's literally a 5-10 minute job. For the wiretap cable, I saved some money and ordered It comes with 3 cables and I used the one with the thinnest plugs.
Nickshu (04-27-2022)
Excellent write-up, very much appreciated.
Hardest step was pulling down that center console. Despite the pics, couldn't get the tabs to unlatch. And didn't have to take down rhe center mirror stalk.
i used the blendmount 15" cord. The thinnest connectors were slightly loose, the next size up was too big. Hopefully the ziptie keeps everything in place.
Nickshu (06-21-2022)
If you have a set if plastic trim tools going under the headliner and A pillar trim to the fuse box is a 5 minute job and far less risky than taking apart the upper console. You don't have to take anything apart, just gently pry and tuck the cord in. For the a pillar section open up the top and then go down the outside edge not the windshield edge.
The following 3 users liked this post by YoshiV819:
Thank you.
Found this post and am so glad I did. I installed the Blendmount tap. Note that you may have trouble with the “standard” tap leads, and should get the Blendmount version with the various sized connectors. (About $20 more.) Thanks again for taking the time. Blendmount should post your instructions because theirs are less than ideal.
Nick—appreciate this great guide! I’ve got a question regarding the cover with the passenger airbag light; how much force would you estimate is necessary to pull it off? Did you simply pull straight down? In one of the first few photos I can see a tab on the inward side(s) of the cover—do they need to be pulled out slightly to release it?
Just wondering if I’m being too gentle or if I need to perhaps use a pry tool…
Thanks!
Matt
Thanks!
Matt
Mind if I ask where you routed the wire tap? I'm using the same (15"), off the vehicle-side wires and using the same mount—and the plug will not reach the V1!. Figures I put all the trim pieces back…
I am thinking perhaps I should order the 20" MTX wiretap.
Thank you for any assistance!
Thanks!
Matt
Thanks!
Matt
Yes the needed length will vary depending on your detector and where you mount. Yes they do make a longer one.
sturmburo (10-21-2022)
Nickshu (10-21-2022)
brown wire inside top light console
While perfectly install the radar, after placing this piece back. One side of the brown wire dropped and is hanging. Does anyone know where it belongs and what this wire actually is?? Thank you in advance.
did you see or had any issues with these wires while installing yours? thank you!
