Macan 2014-Current
Macan V6 - how reliable?
Old 02-08-2022, 08:45 PM
  #31
Jack-Porsche
Jack-Porsche's Avatar
Default Thank you
Originally Posted by dgjks6
2016 Macan S. Just passed 170,000 miles. Burns no oil. Oil changes every 7.5-10,000 miles. No major problems. Sometime well after 100,000 miles developed timing cover leak. The dealer fixed it for me for $129. Replaced a couple bolt and used some sealer. No leaks now.
I want to thank you for your relevant post! No offense to others, but there are so many people who say things like “15,000 and not a single issue”….well I hope not! My goodness, these aren’t Land Rovers!
I put a lot of miles on my daily drivers and your post is good information. Thanks
Blu311 (02-09-2022)
Old 02-08-2022, 09:25 PM
  #32
Noah Fect
Noah Fect's Avatar
Received 1,302 Likes on 887 Posts
Originally Posted by TheMechanic
is racist people OK for you guys?
SA = service advisor, not South Asian (or Sturmabteilung, for that matter.)
boyce89976 (08-21-2023)
Old 02-09-2022, 01:00 AM
  #33
luv2sleep
luv2sleep's Avatar
Originally Posted by CapitalAL
I am also looking at purchasing a 2022 Macan S and was interested in hearing if anyone does their own maintenance on the vehicle and if so how difficult it is to do services like oil change, differential/transfer case fluid changes, brake services and things like that on the 2.9 L engine. I have always done most of the maintenance on my cars so I have a pretty good understanding of working on cars. This is going to be my first Porsche and being at the lower end of Porsche buyers age demographic at 22, I am hoping to be able to do much of the maintenance myself to save some money.
Just do an online search. I have a ‘22 GTS on order and checked out a few “how to” videos because I was bored. I’m a DIYer myself and routine maintenance looks pretty trivial. I once owned a 991.2 GTS and the oil change was easier than on most cars. Porsche stealership would charge over $500. Ridiculous!
Regarding the V6 (3.0 or 2.9), I haven’t read or seen any derogatory reports. They appear to be rock solid power plants otherwise the talent at VAG would not use them in their cars, Porsche or Audi.
Old 02-09-2022, 12:48 PM
  #34
chong0
chong0's Avatar
Is there a tool to reset the service indicator that works for latest gen macans?
Old 02-09-2022, 01:52 PM
  #35
luv2sleep
luv2sleep's Avatar
There are but I don't know which ones work on the latest gen Macans. I'm sure someone on here knows.
Old 08-20-2023, 09:17 PM
  #36
aquamahn
aquamahn's Avatar
zero issues on my 2021 macan s 52,500K on it
Old 08-20-2023, 09:37 PM
  #37
aquamahn
aquamahn's Avatar
"><img src=" /> ">
iCarsoft Auto Diagnostic Scanner POR V2.0 for Porsche with ABS Scan,Oil Service Reset ect iCarsoft Auto Diagnostic Scanner POR V2.0 for Porsche with ABS Scan,Oil Service Reset ect
Old 08-20-2023, 11:29 PM
  #38
john981
john981's Avatar
how about the transfer case issue? I heard it is still ongoing, even for the latest 2023-24 models?
Old 08-21-2023, 12:33 PM
  #39
VAGfan
VAGfan's Avatar
Originally Posted by AnandN
Haha. True. Although the two Porsches I’ve owned/own have been very reliable. Both the 3.4 in my previous Boxster and the turbo six in my C4S didn’t/don’t even drink any oil.
i had two Audis back in the day with the 2.8 V6. Nothing but trouble.
But once the 2.9 is inserted into a Porsche, it will magically transformed to a much better product. Which is why I am planning to order a Macan S.
The Audi 2.8 V6 design (circa 1990's) has nothing to-do with the current Audi 2.9 and 3.0 V6 engines. And the Audi 2.9 and 3.0 engines are 99% the same, other than a slightly shorter stroke on the 2.9, and two turbos instead of one.
Old 08-21-2023, 01:23 PM
  #40
chassis
chassis's Avatar
Received 1,429 Likes on 1,047 Posts
Current Macan with 2.9TTV6 uses a different t/case compared with the earlier version used with the 3.6LV6.
Insufficient information on the new t/case because it is relatively new. Used on Cayenne and Audi models also.
Old 08-21-2023, 01:50 PM
  #41
VAGfan
VAGfan's Avatar
No, the Macan Transfer Case is the same design as introduced in 2015, other than improved durability/hardened clutch discs (used since sometime in 2018).
This Transfer Case is unique to the Macan, not used in any other Porsche or Audi.
The improved Macan Transfer Case seems to have fixed the original problem, but there still are a few cases of late-model failures.
chassis (08-21-2023)
Old 08-23-2023, 10:48 AM
  #42
Zeus993
Zeus993's Avatar
Received 1,273 Likes on 586 Posts
Just picked up a 2018 GTS with 38K miles and here's the list of known issues that I've been able to assemble:
1. Transfer Case failures (warrantied)
2. Cam Cover Gasket oil leaks (I 've have this and will be repaired, warrantied)
3. Air Suspension (this too, will be repaired, warrantied)
4. Leather Dash lifting up (yep, this too, warrantied)
5. Coolant Line Hoses (will crack and leak out fluid)
6. Water Pump failures
7. ...
Quick Reply: Macan V6 - how reliable?
