Transfer Case....Again?
In April 2016, we purchased a 2017 Macan S, and loved every minute of driving it. Then, in Dec 2018, I noticed oil on the garage floor, and the dealership replaced both valve cover gaskets. This resolved the oil issue, but then three months later in March, I noticed the now well-known transfer case issue. The dealership replaced the transfer case and installed a new vibration damper. Problem solved, or so I thought.
Fast forward to last month -- time for new tires, so I had the dealership mount new Pirelli Scorpion Verde's. Along with that, I did a 40k service, which included a PDK flush and refill. Very shortly after, on a long drive, we noticed what seemed to be the same transfer case symptoms -- a stuttering and clunking from a stop through 1st and 2nd gear. At first, I thought it might be the new tires needing a break-in, but after several hundred miles on the tires, I'm doubtful that's the issue. Looking at the dealer invoice for the transfer case repair, the part numbers for the old and new transfer case are the exact same (95B-341-010-X). My understanding is that there is an updated transfer case -- anyone know what the part number is for the update? Has anyone experienced double transfer case failures? Or is there an issue with the PDK service (not enough fluid)?
As much as we love the car, we're really starting to wonder if we should keep it past the warranty period, which expires May 2020. The valve cover and transfer case repairs would have cost us thousands of dollars had this vehicle been out of warranty. Any info or advice appreciated. Thanks!
pop.tremuloides (07-13-2020)
Had my transfer case replaced last week, and I have to say it drives like a totally different car. Smoother in stop-n-go traffic, smoother when accelerating, and of course the grabbiness when turning at low speeds is gone.
I think it's one of those things where you don't really know how bad it is until it's fixed.
The 2017 Macans came out in April of 2016?!?! Wait... What?!
I had heard that Porsche has some weird model introduction dates - this takes the cake!!!
I just had my Transfer Case replaced this week. My SA says he's seen a lot of these failures. My Macan is a 2015 S, with 44K miles. I don't know if it had been replaced before by the prior owner, since I only bought it a year and a half ago at 33K. But I AM glad this was covered by warranty, since it was a $2,600 repair! They put in the 95B-341-010-AX.
Here's a Porsche document about the transfer case up on the NHTSA. Seems the new transfer case has a new coating on the plates which require new software/programming. This will limit DIY replacements down the road if you have the older transfer case.
https://static.nhtsa.gov/odi/tsbs/20...38301-9999.pdf
UPDATE:
Car back from the dealer with the "AX" transfer case installed.
Conveniently, during the drive to the dealership, the instrument panel lit up with the "ENGINE CONTROL FAULT CONSULT WORKSHOP DRIVING PERMITTED" message. Cause was the "ambient temp sensor". Resolution was a software update.
All is well so far. Fingers crossed. Warranty expires in March....
My 2016 Macan S needs a new transfer case, approx. 44000 km (27000 miles), absolutely no abuse. My SA is trying to get it comped as it is off of warranty. Supposedly a new part number, so 2015 and 2016 seem to be affected.
There are three owners here with mid-level mileage on their Macans. So far mine has been trouble-free. It's an '18 Turbo. I've read some early history on the Cayennes. They found that the TC's were failing at a high rate. They at some point mandated the TC fluid be changed every 30K. Whether fact or fiction, Come another 4K at 30,000 miles, I'll be doing my own plugs. But I will take it to a dealership to have the fluid changed as preventative maintenance. If it works, great. If not, I've wasted coin on the fluid changes.
Does a replaced Transfer case, replaced under warranty or goodwill, come with it own warranty? Of an extra year or two? Or does it just fall under the original warranty timeline?
