updated transfer case
So here is my 2018 its 4/18 build date. trying to see of they updated, and when, the failing transfer cases.
That s the part # on my pic.
here is something I found only when looking up part.
but if you notice I have an A (No X).... Would be nice if we can identify new part to give some peace of mind to late build owners.
- Genuine:
- SKU:95B-341-010-AX
- Replaces:95B-341-010-X
Looking at the PET, it shows the following transfer case part numbers. From looking up the part numbers it looks like the 95B-341-010-X is replaced by the 95B-341-010-AX, as you found. The 95B-341-010-A is it's own version. In the far right column is the option/model code. LU2 is Reinforced transfer box. So based on that info in the PET that's the main difference between two versions of part numbers. The part number 95B-341-010-X is the non reinforced transfer box. After that both parts numbers are the reinforced case (-A and -AX). Maybe there's two suppliers and that's why there's two different part numbers.
ottobon100 (07-17-2019)
There are only 2 updated cases A and AX both are currently being sold and started to used 5/3/18. if you have the X case then it’s not updated. Might be best to ask your tech at the dealer that did the work.
You said you had a 4/18 build so you would have the new case, and your picture shows you do.
I looked at my wife's, S and her 2017 has the -X case (older non updated).
cerbomark (07-16-2019)
Hi Guys - I am presently shopping for a '17 GTS for my wife. What is the transfer case issue that necessitated an update/replacement? Thanks for any info you can provide. Michael
High failure rate. Described to me as shuttering, binding. Failures reported with 10K, in some cases sooner. I haven t seen any Porsche information about what and why. Like to know what they changed myself just out of curiosity . Expensive repair FYI.
Our S hasn't had an issue, so it has the older case due to the original build date.
