Sponsored by: APR
GT4 Transmission Failure "Database"
Old 06-28-2017, 02:57 PM
  #181
Alan C.
Alan C.'s Avatar
Received 1,060 Likes on 546 Posts
Originally Posted by Gofishracing
Gentlemen- I believe new units have a different part number now.
Here's the number from a box received at a local dealer last week. 981 300 020 23
Old 06-28-2017, 06:59 PM
  #182
4carl
4carl's Avatar
Received 1,174 Likes on 626 Posts
can someone confirm that the part number on the 15&16 s are the same. if so maybe all are the same and just some welds are failing. if in fact the 15s had a spline( which at this point seems to be speculation) you would think there would be a different part number. correct?
Old 06-29-2017, 08:28 AM
  #183
d00d
d00d's Avatar
The 20160713 PET shows the replacement transmission as part 981 300 020 22.
Since most of the failures are from 2016 production (mooty and orthojoe had 2015 failures), and we have not to my knowledge seen internal pictures with a splined third, you could be right that all are EB welded and just the latter production had a weaker weld.
It could instead be that Getrag made a running change and didn't tell Porsche, and therefore replacement 981 300 020 22 is either splined or welded depending on when it was made.
Replacement 981 300 020 23 could either be splined or a stronger weld, thanks to Porsche's silence we just don't know.
Old 06-29-2017, 09:16 AM
  #184
4carl
4carl's Avatar
this sucks!
Old 06-29-2017, 10:03 AM
  #185
Warwick Morris
Warwick Morris's Avatar
At this point someone (independent) who has opened-up a gearbox should chime in and settled this; Splined or welded? GT Gears where are you?
Old 06-29-2017, 10:36 AM
  #186
Buteo
Buteo's Avatar
They ( GTgears) did. Either this transmission thread or the other. The gear was pulled from sharkwerks car and it was EB welded.
Old 06-29-2017, 10:40 AM
  #187
needmoregarage
needmoregarage's Avatar
Received 1,538 Likes on 659 Posts
I'll be adding a friend's 3rd gear failure to the spreadsheet. This person prefers to remain anonymous.
March 2016 build (they were not positive) and approx 10,000+ miles
Didn't give track miles which I"ll find out before I put it on the spreadsheet.
Old 06-29-2017, 12:06 PM
  #188
d00d
d00d's Avatar
Right, but has there been a GT4 transmission that's been opened to find a splined 3rd?
Old 06-29-2017, 01:09 PM
  #189
GTgears
GTgears's Avatar
We have replaced about 2 dozen gearsets on GT4s at this point and all 3rds have been welded. But none of these cars have had a replacement gearbox in them.
I'm about to make a new batch of gears because Sharky keeps selling them all. I am going to make half a dozen stock ratio for guys who are tired of gambling.
Old 06-29-2017, 03:58 PM
  #190
4carl
4carl's Avatar
in that case its a bad batch of welds not a design change from splined
Old 06-29-2017, 05:10 PM
  #191
Alan C.
Alan C.'s Avatar
I took a look at my Certificate of Authenticity and the actual production date for my car was 10/14/2015. 12,000 miles and no issues.
Old 06-29-2017, 08:21 PM
  #192
sharkster
sharkster's Avatar
If only it wasn't more fun and peppy your gears tho Come on over next time and we'll make a fun "Stock" xmas tree with the old left over gear piles we've got
Old 06-29-2017, 09:10 PM
  #193
GTgears
GTgears's Avatar
How do you come to that conclusion?
Old 06-30-2017, 01:05 AM
  #194
4carl
4carl's Avatar
From your comment that all the gears you removed were welded. Maybe I misunderstood ?
Old 06-30-2017, 01:13 AM
  #195
Buteo
Buteo's Avatar
what makes you think ANY of the gear boxes are splined 3rd gear? Failures encompass nearly all months of production and both years ('15&'16).
I would find it odd Porsche (getrag) offered two different versions of the box (increased cost). I'd wager all are EB welded.
Quick Reply: GT4 Transmission Failure "Database"
