Sponsored by: APR
GT4 G81 Transmission Failure
Old 10-29-2016, 04:12 PM
  #91
Jc underwave
Jc underwave's Avatar
Default French gt4
Hello guys ! My gt4 is a june 2015 . 9000 km , 7000 of tracks . No problem of gearbox . My only problem is the pucks of the brake calipers . I will have to change the front calipers for the second time before the next season .. i join you photos of my gt4
Old 10-29-2016, 05:45 PM
  #92
bhk1004
bhk1004's Avatar
what is the pucks of the brake calipers? do you mean the pistons?
Old 10-29-2016, 05:53 PM
  #93
Spyerx
Spyerx's Avatar
Received 1,844 Likes on 1,123 Posts
What brake pads are you using? (You may want to start another thread for this... this is a known issue)
Old 10-29-2016, 06:45 PM
  #94
Jc underwave
Default French gt4
a pic is better to explain !!
Old 10-29-2016, 06:57 PM
  #95
Jc underwave
Default French gt4
the brake pad are porsche original . I always used pagid yellow but for gt4 ,i like the braking , so i stay like this ... do u think there's a better choice?
Old 10-29-2016, 07:54 PM
  #96
PorscheRuminator
PorscheRuminator's Avatar
Location: Chicagoland USA "Turn On, Turn In, Track Out"
Back to the original issue re the transmission, my 3rd gear failure was a 981 GTS, not a GT4, so if the two transmissions are different it seems to be affecting both, unless there is a common part.
Old 10-29-2016, 08:08 PM
  #97
orthojoe
orthojoe's Avatar
Oem and pagids will do that because of tapering. Stick with ferodo ds1.11, pfc11, or endless me20 and that won't happen anymore
Old 10-29-2016, 08:11 PM
  #98
4carl
4carl's Avatar
Received 1,186 Likes on 635 Posts
Do all 981 boxes have the same welded 3rd gear or just the GT4?? This is key..
I used to own a welding supply business in another life. A weld with full penetration is stronger than the base metal.Could be nothing more than a batch of bad welds. Machine settings and amperage settings that changed which would affect penetration and strength. carl
Old 10-29-2016, 09:13 PM
  #99
jfr0317
jfr0317's Avatar
As a retired pipeline engineer, weld quality was also the first thing I thought of. Interesting that all of the reports that mention delivery dates seem to have been 2016 dates. Has anyone with a 2015 calendar year production date suffered this type of failure yet?
Old 10-30-2016, 01:47 AM
  #100
GTgears
GTgears's Avatar
so the regular 981 box 3rd is splined ? you make a reference to the 987 gear box being splined but not the 981 . Is it only the gt4 /spyder box that 3rd is welded ?
I don't know anyone who has been inside one. Until I saw Sharkie's take out gears we had no reason the believe they had changed the design/manufacturing technique. My guess would be that all 3rd&4th gears are now done this way.
I don't see how it could be a bad "batch" of welds. These are computer generated welds and I don't think the machine would ever have its program altered. .I have a different theory. I think the reason it is happening on 3rd is because the synchro teeth overhang the gear. I think the synchro teeth is flexing and cracking the welds.
Back to the question about the 981 base box? No idea if they will start breaking. It is a different ratio. It will overhang less.
Lastly my gears are splined. All 4 ratios 3-6 are splined. We wanted the teeth to be replaceable.
Old 10-30-2016, 01:59 AM
  #101
mooty
GT3 player par excellence
mooty's Avatar
Received 5,861 Likes on 2,398 Posts
^ you call bill and he will be able to confirm with another gear box that if 3rd and 4th teeth are welded.
Old 10-30-2016, 02:50 AM
  #102
4carl
4carl's Avatar
Please correct me if I'm wrong but aren't we back to the orginal question..What is different if anything about the GT4 gear box?
If I'm understanding what you are saying is that all third gears are welded on all 981 gear boxes. Correct? Thanks carl
Old 10-30-2016, 02:53 AM
  #103
4carl
4carl's Avatar
delete
Old 10-30-2016, 04:03 AM
  #104
Jc underwave
thank you orthojoe . I will try ferodo .
Old 10-30-2016, 11:41 AM
  #105
GTgears
GTgears's Avatar
I repeat, I don't know if they are all welded now because I haven't been in one, but its a safe guess.
Quick Reply: GT4 G81 Transmission Failure
