Sponsored by: APR
Hoosier Trial Fit
Old 09-16-2016, 04:31 PM
Bill Lehman
Bill Lehman's Avatar
Default Hoosier Trial Fit
Here's some shots of Hoosier 235-35 19 R7 on an OZ 19 x 8.5 ET53 and Hoosier 295-30 19 R7 on an OZ 19 x 10 ET40. I did not see any clearance issues.
Old 09-16-2016, 05:25 PM
kyrocks
kyrocks's Avatar
I have 265 in front and 295 in rear. No issues.
Old 09-16-2016, 05:36 PM
gulf911
gulf911's Avatar
Hi Bill,
What is the consensus about OZ not being forged for track use? Also , what is the model of the OZ wheel you are using here? I would love to use this solution if it works.
Also , is this a stock alignment?
Thank you!
Dan
Old 09-16-2016, 05:45 PM
jslee225
jslee225's Avatar
on same oz wheels?
Old 09-16-2016, 05:53 PM
gulf911
gulf911's Avatar
Looked on Tire Rack , Leggera HLT?
Old 09-16-2016, 06:23 PM
kyrocks
kyrocks's Avatar
Originally Posted by jslee225
on same oz wheels?
Forgeline 9 " front , 10.5" rear
Old 09-16-2016, 07:05 PM
Tplgt4
Tplgt4's Avatar
What is the difference in revs per mile between the slicks and the OE tires?
Old 09-16-2016, 07:10 PM
jslee225
jslee225's Avatar
figured! I may be getting some soon! I should have got forgelines in the first place.
Old 09-16-2016, 07:12 PM
jslee225
jslee225's Avatar
yes
Old 09-16-2016, 07:17 PM
kfmcmahon
kfmcmahon's Avatar
camber plates and toe links with those sizes?
Old 09-16-2016, 07:29 PM
kfmcmahon
kfmcmahon's Avatar
looking for the same set up....did you have Tire rack mount the hoosiers and tpms?
I know when you look for a "wheel and tire" package from them (in -1 size for 19") they don't give the R7 as a choice, but rather the RE-71 and a few others
anxious to hear your review of tire/wheel package vs OEM
Old 09-16-2016, 07:49 PM
Bill Lehman
I originally had Tire Rack quote these wheels with these Hoosiers. I decided to run street tires to get a better handle on the GT4 handling and had Tire Rack change the quote and switch to RE-71R. I also bought their TPMS senders installed. I have run 3 events with the Bridgestones and decided to try the Hoosiers (I'm an Instructor and have run R comps for 7 years). Bought the Hoosiers and had them mounted locally. If I did it again I would not bother with the TPMS. "Circuit Mode" is next to useless.
Old 09-16-2016, 08:56 PM
kfmcmahon
kfmcmahon's Avatar
I agree circuit mode is pretty useless, but I like to see pressures on screen while I drive to get a feel for grip/greasiness as pressures rise.
I run R7's on my GT3 and consistently find feel and lap times, for me, are best at 35F 36R (-/+1 or 2 right-to-left depending on CW or CCW track direction)...so seeing these numbers on screen confirm what target "hot" pressures to shoot for.
Old 09-16-2016, 09:11 PM
kyrocks
kyrocks's Avatar
RSS Toe links, no camber plates.
Old 09-16-2016, 09:17 PM
paradocs98
paradocs98's Avatar
More important, gorgeous garage floor! What product did you use?
What aspect ratio? 265/30-19 and 295/30-19?
Quick Reply: Hoosier Trial Fit
