who runs R7 on GT4
#31
Originally Posted by usctrojanGT3
450 front and 550 rear swift springs. Then set the front sway to full soft and rear sway to full stiff. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Now that more GT4 owners are getting their cars to the track it's interesting to see how widespread the understeer and tire wear issues are becoming. While most folks are attempting to address this through alignment modifications I think more people will eventually follow Trojan's lead and they'll come around to understanding that stiffer springs and roll bars will be much more effective at resolving these issues. Race shops have already begun to do this to some customers' cars but they're not posting details here. These problems are not endemic to the 981 platform per se. Once it's set up properly the 981 platform is fantastic. This is just a matter of fine tuning some of the components. And it won't be terribly pricey to do this.
#32
Site search revealed 257/457 Front/Rear stock. GT4 Clubsport running 800/800. At what spring rate do you run risk of being out of the damper range? Would adding a DSC sport controller let you program for a stiffer spring?
#33
GT3 player par excellence
450/550 u are closr to limit of dampers
8@0/800 on CS is totally different.
#34
Yeah, that sounds about right. My suspension guy said be almost doubled the front spring stiffness in the front and bumped the rear by 20-25%. He recommended I don't go any higher than 450/550 unless I revalued the OEM dampers or went to aftermarket ones like JRZs, KWs, or Ohlins.
#36
I agree that 3.2 is a lot for a street car. A pyrometer would only confirm what is already evident from the tire wear. The stock suspension is too soft, especially the front springs. With all the grip these tires are generating there is an excessive amount of body roll.
#38
-3.5F/-3R didn't help much this weekend at TWS. Car was ludicrous fast, but it just grinds off the outer 2 inches of tire. Temp profile was pretty good on the front, but the rear was too steep, -3R is too much.
Springs next I guess.
Tire pressure wise, I kept it under 38 on track, which translated into 23 dead cold. Seemed to work OK.
#39
#40
(Taken on different track days)
Purple (1:50ish) = Andy Lally in a .2RS new R6 tires (open track)
Blue (1:48) = GT4 with 2-cycle R7 tires (and proper alignment, but DE traffic)
Red (1:48) = .2RS with new Pirelli DH (open track)
#41
#42
1) I wanted the F/R diameter ratios to be close to stock, 2) gearing, 3) ride height, and 4) more space in the fender.
#43
TWSCCW sub 1:50 is very impressive and a little surprising vs the 7.2 RS, but the data doesn't lie. Maybe a little cooler conditions for the GT4 lap? In any case that is hauling the mail. Thanks for posting.
#44
great i have same size wheels.
265 is great, what i want to hear.
i do not think front full stiff will work on this car
i would start one off stiff or middle.
toe OUT front is must imo
i plan to start at -3 front and -2.75.
but i wont have time to test it until june, my private day.
there will be 3 decently fast GT4 and 1 really really fast one. so we should have some info
I would go to 235 on a 9 wheel. Run it hot at ~ 38psi
if my gt4 gets here before your event we can compare
#45
265 seems like a way too much tire which will induce understeer and premature tire wear. Too much side wall flex. The contact patch of 235 will be same or close to 265 and no side wall flexing.
if my gt4 gets here before your event we can compare![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
