who runs R7 on GT4
GT3 player par excellence
265 is great, what i want to hear.
i do not think front full stiff will work on this car
i would start one off stiff or middle.
toe OUT front is must imo
i plan to start at -3 front and -2.75.
but i wont have time to test it until june, my private day.
there will be 3 decently fast GT4 and 1 really really fast one. so we should have some info
I have a set of the OZ rims in the garage with 235 and 295/30 R7s. Fit nicely on the rims. Haven't had a chance to run them yet. Will update when I have (hopefully before the end of April). On the factory Dunlops, with -2.75f/-2.25 rear, and bar full soft front, middle rear, get mild but easily adjustable understeer and tires are actually wearing pretty well. I imagine and plan with Hoosiers to go to around 3 or 3.2 front and 2.5 rear but that could change.
^ I'm guessing of course, but u are at full soft front with mild push, 235-295 will push more.
I was hoping to run 255 front but snb is on 265 (surprised that fits, but I love it) I will try that first. can't wait... but too much work in April and have here day race in May. so June it is
plate?
u have camber plates? tarrett?
Yes, while I didn't start there, we added them to get another 1/2 degree without adding the risk of tire rubbing that shims would bring.
Yes, plates have a similar effect to shims in moving the lower control arm forward.
yes ideally do both shim and camber plates
I run bbs e88
and forgeline ga1r
I run bbs e88
and forgeline ga1r
Yes, I know. The car is too soft for a strut based chassis and I was not running enough camber before. I got about the same from a set of rear tires on the RS - but that is a totally different beast, so it's not that bad in the grand scheme of things. I think with the right alignment and some more driving finesse I could get 1-1.5 more days from them. I may try running the front bar full stiff as well. We're all learning how to make this car work.....
I don't need R7s as I'm fast enough on my RE-71s that'll last me 20+ HCs.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I know I know....we're getting there. That's next. What exactly did you get again?
