Forgeline GA1R with Track alignment
Well, finally have a clean car so I'm not embarrassed to show how things turned out with the alignment and track wheels.
These are Forgeline GA1R with open lugs (center machined out to save 0.5lb per wheel). These are track wheels, so I didn't bother with a center cap.
19 x 11 ET45
19 x 9 ET48
Each front is about 2lbs lighter than OEM (wow OEMs are really light!)
Each rear is about 3lbs lighter than OEM
I'm trying out a hoosier R7 265/35/R19 and 295/30R19 setup.
Each front wheel & tire is 2lbs lighter than OEM 20"
Each rear wheel & tire is 7lbs lighter than OEM 20"
Give me 18lb rotational mass savings - not too bad. Still amazed at how light the OEM wheels are.
Alignment Front:
-5mm ride height to offset 265 size
-3 Degrees Camber
9.3 Caster
1mm total toe out
Wheel is perfectly centered in wheel well
Alignment Rear:
-2.5 Camber
4mm total toe in
We used shims with thrust-arm bushings to get this, and I'd guess the track is about 0.75"-1" wider F/R.
![Name: DSC_0499.jpg
Size: 408.5 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005449d1451355624-forgeline-ga1r-with-track-alignment-dsc_0499.jpg)
![Name: DSC_0497.jpg
Size: 255.2 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005450d1451355624-forgeline-ga1r-with-track-alignment-dsc_0497.jpg)
![Name: DSC_0505.jpg
Size: 278.5 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005451d1451355624-forgeline-ga1r-with-track-alignment-dsc_0505.jpg)
![Name: DSC_0512.jpg
Size: 252.7 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005452d1451355624-forgeline-ga1r-with-track-alignment-dsc_0512.jpg)
![Name: DSC_0511.jpg
Size: 335.5 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005453d1451355624-forgeline-ga1r-with-track-alignment-dsc_0511.jpg)
![Name: DSC_0517.jpg
Size: 281.5 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005454d1451355624-forgeline-ga1r-with-track-alignment-dsc_0517.jpg)
![Name: DSC_0516.jpg
Size: 299.0 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005455d1451355624-forgeline-ga1r-with-track-alignment-dsc_0516.jpg)
![Name: DSC_0507.jpg
Size: 258.3 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005456d1451355624-forgeline-ga1r-with-track-alignment-dsc_0507.jpg)
Thrust Arm Bushings and Shims
![Name: IMG_5795.jpg
Size: 203.9 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005457d1451355624-forgeline-ga1r-with-track-alignment-img_5795.jpg)
Very close to toe arm, maybe 4mm.
19 x 11 ET45
19 x 9 ET48
Alignment Front:
-3 Degrees Camber
9.3 Caster
1mm total toe out
Alignment Rear:
-2.5 Camber
4mm total toe in
![Name: IMG_5712.jpg
Size: 277.3 KB](https://rennlist.com/forums/attachments/gt4-spyder/1005458d1451355624-forgeline-ga1r-with-track-alignment-img_5712.jpg)
Great post. I thank you,
First, the setup looks fantastic. tire sizes aside.. spot on.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Any concerns with the fronts rubbing? that extra tire and width really pushes it out..
Solid setup man.. looks great!
proper. looks good.
Man that's an aggressive setup. For the street the tires stick out too far IMO but at the track it should be pretty awesome. One suggestion is to do something to protect the body work from rubber and debris being kicked up, especially behind the fronts.
Any concerns about that small clearance between the wheel and toe arm?
Very interested to hear your feedback on the car with those alignment specs.
The car should have came with 19s
Looks great, I have the same wheels coming in a Titanium finish for my Sapphire Blue GT4 that is currently somewhere in the Atlantic on its way. Forge line makes great wheels even have a set on my Cayenne Diesel
Excellent setup! Very interested in your thoughts once you get it on track.
YES!!! this car will be a beast on sticky rubber. looks excellent!
Look forward to your feedback. did you track on any other setup prior to this?
There is enough clearance between the wheel and the rear toe arm that unless the wheel fails, I doubt they will ever touch. I could not run an offset that brings the edge any closer though.
Thanks guys!
Basic Sponsor
19 x 11 ET45
19 x 9 ET48
Alignment Front:
-3 Degrees Camber
9.3 Caster
1mm total toe out
Alignment Rear:
-2.5 Camber
4mm total toe in
Attachment 1005449
Attachment 1005450
Attachment 1005451
Attachment 1005452
Attachment 1005453
Attachment 1005454
Attachment 1005455
Attachment 1005456
Attachment 1005457
Attachment 1005458
19 x 11 ET45
19 x 9 ET48
Alignment Front:
-3 Degrees Camber
9.3 Caster
1mm total toe out
Alignment Rear:
-2.5 Camber
4mm total toe in
Attachment 1005449
Attachment 1005450
Attachment 1005451
Attachment 1005452
Attachment 1005453
Attachment 1005454
Attachment 1005455
Attachment 1005456
Attachment 1005457
Attachment 1005458
I'd also be concerned about stuff being thrown into the side intakes.
