Forgeline GA1R with Track alignment
#106
back to Forgelines - any preference on the "colors" available? I am thinking Transparent Smoke. But a riskier choice is Transparent GOLD or Transparent RED. Thoughts? My car when it arrives in early April is JBM. I also love the MATTE transparent red and gold. I know, a bit blingy, but for sweet track wheels in 19 . . . maybe? opinions please.
Race Gold - Satin
![Name: power satin gold.jpg
Size: 185.1 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024991d1456585575-forgeline-ga1r-with-track-alignment-power-satin-gold.jpg)
Race Gold - Gloss
![Name: gloss race gold.jpg
Size: 170.7 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024996d1456585677-forgeline-ga1r-with-track-alignment-gloss-race-gold.jpg)
Matte Gold (not race gold)
![Name: matt gold.jpg
Size: 157.4 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024992d1456585575-forgeline-ga1r-with-track-alignment-matt-gold.jpg)
Transparent Gold - Gloss (looks like anodised and brushed)
![Name: gloss transparent gold.jpg
Size: 196.2 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024994d1456585575-forgeline-ga1r-with-track-alignment-gloss-transparent-gold.jpg)
Transparent Gold - Matte (looks like anodised and brushed)
![Name: matt transparent Gold.jpg
Size: 200.1 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024995d1456585575-forgeline-ga1r-with-track-alignment-matt-transparent-gold.jpg)
Bronze- Satin
![Name: satin bronze.jpg
Size: 148.9 KB](https://rennlist.com/forums/attachments/gt4-spyder/1024993d1456585575-forgeline-ga1r-with-track-alignment-satin-bronze.jpg)
#107
Okay, I should GO BIG as I look at these golds. The Transparent Matte Gold looks awfully good. Very hard to choose, maybe I should get pricing on the various colors as that good help make the decision.
#108
transparent matte BRONZE might be killer too, if there is such a color
#109
The transparent colors add 150 per wheel. The standard colors are "free".
#111
#112
^ Agreed
#113
Delete
#114
Update on the setup.
R7s will last about 3 days, possibly 4 days if I can get the fronts to more evenly wear.
Pressures: Well, even though the R7 product manager said to run high pressures, the tires work much better (I know others have said the same...) with lower pressures. I was keeping them under 40psi on-track-hot, and they worked better than letting them get above 40.
Alignment: I am handing the car over to soulspeed this week to add another -0.5 degrees on the front using camber plates. The rear could use another -0.25-0.5, but since they are wear much more slowly that the fronts and I'm happy with the feel and grip, I probably will not bother.
My thoughts on why camber plates are the way to go with this wide front setup to achieve some of the negative camber.
![Name: Camber (3).jpg
Size: 23.4 KB](https://rennlist.com/forums/attachments/gt4-spyder/1030587d1457966160-forgeline-ga1r-with-track-alignment-camber-3-.jpg)
![Name: Camber (1).jpg
Size: 23.7 KB](https://rennlist.com/forums/attachments/gt4-spyder/1030588d1457966160-forgeline-ga1r-with-track-alignment-camber-1-.jpg)
![Name: Camber (2).jpg
Size: 26.3 KB](https://rennlist.com/forums/attachments/gt4-spyder/1030589d1457966160-forgeline-ga1r-with-track-alignment-camber-2-.jpg)
#115
I run R7's on my 987 between 32 - 34psi hot. This is well below what Hoosier recommends. But this is what most of us with 987 track/race cars are doing and the results have been excellent. I suggest you shoot for pressures not to exceed 35psi hot and see for yourself. Lower may be better.
#116
I run R7's on my 987 between 32 - 34psi hot. This is well below what Hoosier recommends. But this is what most of us with 987 track/race cars are doing and the results have been excellent. I suggest you shoot for pressures not to exceed 35psi hot and see for yourself. Lower may be better. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
#117
Originally Posted by ShakeNBake
Yep...learning that lesson. Tires were fastest on the first hot lap, pressures reading about 32-34.
#118
I agree that lower pressures seemed better for me as well. I think I went down to 36 hot but may try lower next event. My cold pressures will be very low but I'll give 32F/34R a try next time.
#119
