Sponsored by: APR
Coolant error on new GT4
Old 11-24-2015 | 09:19 PM
FergusH's Avatar
FergusH
Default Coolant error on new GT4
I picked up my GT4 on Sunday and got this error several times on the way home:
An overheat error came up first but was then quickly replaced by this error, almost as if the car is saying "I'm too hot...wait, I only think I'm too hot".
The car is back at the dealer now and I'm driving the *exact* opposite of a GT4 (Cayenne, but even better a diesel Cayenne!). I'm sure it'll get sorted out ok but I'm curious if anyone else has seen the same problem.
Thanks.
Edit: I found a picture on the Internet of the overheat error I get first. The yellow caution message appears immediately after.
Old 11-24-2015 | 09:29 PM
neanicu's Avatar
neanicu
It's probably a faulty thermostat. Very common on the 9A1s. I haven't heard of this problem on the GT4.
Old 11-24-2015 | 10:15 PM
STALKER99's Avatar
STALKER99
Did the coolant temp actually increase???
I'm not sure if the Cayman is the same as the 991 but I would get a similar error code on my 991 C4S but it was simply caused by an exhaust vaccum line that is poorly placed, since it would melt. My temps would be perfect though.
Old 11-25-2015 | 12:18 AM
FergusH's Avatar
FergusH
No, the coolant temp was in the normal range.
Old 11-25-2015 | 12:46 AM
csbear's Avatar
csbear
Possibly a thermostat issue as mentioned by neanicu, which is not that bad if that's the case. Should be an easy fix then..
Old 11-25-2015 | 01:32 AM
David Schacht's Avatar
David Schacht
I had a similar problem with my 987 CS, it was a coolant temp sensor
Old 11-25-2015 | 09:07 AM
BRNGT4's Avatar
BRNGT4
Have you installed an exhaust on your car? Is the Vacuum hose that actuates the exhust flap damaged or disconnected. If so that is your fault right there. The vacuum hose that attaches to the exhust if damaged throws a coolant error. why i dont know but that is the case.
Old 11-25-2015 | 09:41 AM
BGB Motorsports's Avatar
BGB Motorsports
Basic Sponsor
The reason that fault occurs like that is because the vacuum for the PSE is the same vacuum that opens and closes coolant doors for heat exchanger warm up and circulation. I think your guess is probably correct but without seeing the fault in the DME it's hard to be 100% certain.
One of our first conversions had that same fault til we wired the flaps shut on the aftermarket exhaust to determine the cause and then it was okay.
BGB Motorsports Group
Old 11-25-2015 | 11:27 AM
FergusH's Avatar
FergusH
No, totally stock. Hopefully I'll hear something today.
Old 11-25-2015 | 06:13 PM
shewu's Avatar
shewu
Thanks.
Completely OT and apologies in advance for hijacking, but CONGRATS! I only knew that you got the GT4 from stumbling upon this thread. Happy early Thanksgiving!
Old 11-26-2015 | 12:15 AM
FergusH's Avatar
FergusH
Got a call from the dealer today saying the car was ready. Great! Five minutes after picking it up, exactly the same error appeared again. Not great. Back in the loaner Cayenne until after Thanksgiving while they fix my car.
Old 11-26-2015 | 12:27 AM
bhk1004's Avatar
bhk1004
Wow that sucks. Could post the original diagnosis by the dealer? I guess this second time it'll be something else so that would be nice info also.
Old 11-26-2015 | 10:15 AM
BryanCO's Avatar
BryanCO
What the heck! Doesn't provide a lot of confidence for that dealer...
Old 11-26-2015 | 10:33 AM
sccchiii's Avatar
sccchiii
very likely a stuck thermostat.
Old 11-26-2015 | 11:11 AM
LexVan's Avatar
LexVan
We've had a ton of these on the 991 Forum. This is the change/cross over valve issue. IIRC. Search over there.
Quick Reply: Coolant error on new GT4
