Sponsored by: APR
Coolant error on new GT4
Old 12-08-2015 | 11:59 AM
  #46
LexVan's Avatar
LexVan
Originally Posted by FergusH
Not sure. Perhaps there were two cycles of draining and refilling?
Hope they used distilled water to make the right ratio.
Old 12-08-2015 | 12:02 PM
  #47
neanicu's Avatar
neanicu
Any thoughts on the "no flow of coolant radiator" comment? I don't understand that part.
There's only one thermostat on this car. But it is housed in a pipe that contains a bypass system. The bypass is used for fast heating of the engine and it can also direct the flow of coolant to the third radiator depending on demand. Like when you press the sport button.
So I suspect that the malfunctioning thermostat or temp sensor were not allowing the bypass system to operate as intended and stopping the flow to the 3rd radiator.
Old 12-08-2015 | 12:03 PM
  #48
FergusH's Avatar
FergusH
Interesting. Thanks for the info. I'll probably try to schedule a call with the mechanic who worked on the car to get the full run down.
Old 12-08-2015 | 12:23 PM
  #49
neanicu's Avatar
neanicu
Here read this and see after if the technician knows more than you :
Old 12-08-2015 | 12:24 PM
  #50
neanicu's Avatar
neanicu
And this :
Old 12-08-2015 | 12:27 PM
  #51
neanicu's Avatar
neanicu
This :
Old 12-08-2015 | 12:31 PM
  #52
neanicu's Avatar
neanicu
Finally :
Old 12-10-2015 | 03:31 PM
  #53
Gofishracing's Avatar
Gofishracing
wow
Quick Reply: Coolant error on new GT4
