Sponsored by: APR
Katmeho's GT4 Track Day Oriented Journal
Old 06-04-2016, 11:27 AM
  #226
orthojoe
orthojoe's Avatar
Thanks for coming out despite the heat. Hope you guys can do the next event as well!
Old 06-04-2016, 04:15 PM
  #227
mooty
GT3 player par excellence
mooty's Avatar
Received 5,635 Likes on 2,318 Posts
^ dude make sure you call someone to block the sun and no rain. 70 deg would be just peechee!
Old 06-13-2016, 12:08 PM
  #228
katmeho
katmeho's Avatar
Default Laguna - June 11 2016
Got out Saturday at Laguna and had a great day running with Mooty and some quick SoCal TT guy. This was my first GGR event and they run a nice event, although it's not a ton of on track time. Private days spoil you for seat time.
Ran a PB 1:41:80 and think I can get into the 1:40's if I focus. The whole lifting for sound bothers me but looking at the recent posting for the HAL 9000 solution leads me to think the lifts will soon go away. I think I'm loosing .25 seconds so really I just need to put a proper lap together. Theoretical best was a low 1:39 so it's there. And Joes easily putting it all together. ��
The placement of the SmartyCam external mic into the car seat anchor latch behind the passenger seats works well and gives me sound that is good enough for my liking. I posted a video of me making a mistake in T2 trying to catch Mooty to illustrate the audio setup.
I had new PSC2s for the event and I had been targeting 32/33 psi hot for sessions. I'm starting to thing that they might have a touch more grip at 34/35 hot. My first session had them around 35 (but the track was cooler) and I was left with the impression of more control. I could have just been driving smoother but now I want to try out a tiny higher psi. Anyone got any thoughts on that?
Old 06-13-2016, 12:16 PM
  #229
myBailey07
myBailey07's Avatar
I have concluded the same and my temp readings I have done, although not extensive, have showed the same. I have settled on 34/34.5 for now and it feels good. I have never felt that 32 feels better. Going a bit higher will also be a bit better for the outer edge wear on the cup 2's.
Old 06-13-2016, 12:31 PM
  #230
RDCR
RDCR's Avatar
Matt that is a great time given you were lifting! Can you post some video of you going thru 5 to 6? I'm going there weds and still don't have a solution. I've only driven LS once so far in the GT4 and I'm pretty sure I'm going thru there slower then I need to (especially if you're only losing .25.)
thanks Rich
Old 06-13-2016, 12:43 PM
  #231
katmeho
katmeho's Avatar
thanks Rich
I'll pull my PB from the camera tonight. I'm losing time in T2 and into and out of T11. The lifts not hurting me too much. But inconsistency is. I also seem to be really unsure of breaking into the cork screw. Sometime it's a double tap once over the crest and sometimes it's all brake before the plateau etc. need to figure that out. I expect Joes video would show us the way!
Old 06-13-2016, 12:56 PM
  #232
orthojoe
orthojoe's Avatar
Sorry I missed running on Saturday with you guys. Would have been really fun. There was plenty of open space Sunday, but traffic on the way home was killer. See you Friday!
Old 06-13-2016, 06:47 PM
  #233
matttheboatman
matttheboatman's Avatar
Excellent wide angle video and great audio, Katman! Thank for sharing.
I will look into doing the same. What mount did you use to secure to the seat's backrest?
Old 06-13-2016, 07:41 PM
  #234
katmeho
katmeho's Avatar
SmartyCam is mounted to the cross brace of the GMG bar via Ram mount ball joint. Mic cable just fished into the child seat slot.
Old 06-14-2016, 02:27 PM
  #235
matttheboatman
Old 06-15-2016, 12:44 AM
  #236
stingray84
stingray84's Avatar
Sounds pretty decent. I like having a permanent mic in the car that you just need to plug into the camera on track days. I'm looking into replicating what you did or routing the mic near the exhaust and attach to the inside of the rear bumper. The later will probably sound better. But I'm worried about the mic failing over time due to the harsh environment (heat, water, dust)
What mic did you use? Is it a generic mic with 3.5mm cable or some special SmartyCam mic?
Old 06-15-2016, 01:06 AM
  #237
katmeho
katmeho's Avatar
It's the AIM Can cable with integrated external mic. Part is available from the Aim SmartyCam page under accessories. Part number on the title slide of the video. Easy to get from any Aim reseller.
Old 06-16-2016, 12:27 AM
  #238
katmeho
katmeho's Avatar
thanks Rich
Heres the lap with the lift. Watching it again, theres still a lot more in the lap for me to capitalize on.
Old 06-16-2016, 11:43 AM
  #239
RDCR
RDCR's Avatar
Drove LS yesterday with HOD - 90db day. Blew sound twice running out of 5. Any throttle in 3rd didn't cut it. I had to stay in 4th and keep it under 5500 RPM. Hoping the GPS controller will be good for 90 db days as well.
I still managed a PB for me of 1:44 which was 4 seconds better then I had done in the Cayman R so I'm ecstatic with the car.
One difference I noticed after watching your video and Joe's was how we are driving turn 3. Joe is going back to second where it appears you are staying in 3rd which is how I was driving it as well. It does feel to me like 3rd is a little tall to get a good track out of 3 (at least at my exit speed) but getting to 3rd and then right back to second in the 2-3 straight seemed like a hassle the one time I tried it. I think I will work on doing that next visit there.
I went with staying in 3rd thru the corkscrew after watching you guys - much better!
Rich
Old 06-17-2016, 02:35 AM
  #240
katmeho
katmeho's Avatar
Hotel, motel, Holiday Iiiiiiiinnnnnnn....
Go Mooty track day Go!
Quick Reply: Katmeho's GT4 Track Day Oriented Journal
