Sponsored by: APR
True GT4 weight and suspension info.
Old 08-23-2015, 01:33 PM
fishing
fishing's Avatar
Wow, just waiting for aftermarket lighter wheels.
Old 08-23-2015, 01:56 PM
4carl
4carl's Avatar
Received 1,176 Likes on 628 Posts
Originally Posted by Petevb
I'm trying to connect the dots to the factory listed weight to see how close they come. Can you list you car's options?
Small fuel tank?
Radio / AC delete?
The factory says they quote weights per DIN in the lightest possible spec, so all of the above plus buckets, pccb, etc, fluids near full, no options that add weight. I'm curious to see if they are accurate or light this time.
My car was weighed with 1/2 tank=8 gal even took out the books from the glove box ! Steel brakes and the manual sport seats=3083.0 LBS..
There's no way in hell you are going to get the car under 3000lbs unless you go nuts . No Ac or sound system plexiglass windows stripped interior small battery lighter wheels ect. I've been through the weight loss drill with Lotus's. The work/cost/reward ratio isn't good. Not to mention you take the pipe on resale! carl
Old 08-23-2015, 03:44 PM
khooni
khooni's Avatar
ac/radio delete / lithium battery and PCCB do take out near 110lbs...... which would take it under 3,000 lb
when i had my boxster spyder
i had pccb/ac delete with sound plus CDR and came in at the 1275kg din weight once I ditched the roof with a full tank of gas.
Old 08-23-2015, 03:53 PM
Rob VN
Rob VN's Avatar
Default Alignment Check
Carl,
That outer ball joint nut doesn't seem to have any threads protruding from it. Was it in partial disassembly already?
Will you be checking/setting your alignment shortly? What method do you use?
What are the sway bar settings that can reduce under steer for GT4
Thanks,
Rob
Old 08-23-2015, 04:12 PM
Accel Junky
Accel Junky's Avatar
Carl, I just weighed my GT4 with reg seats, steel brakes, extended leather w/ platinum stitching, fire extinguisher, carbon trim, smoker's pkg, and a full extended tank of 93 at 3117 lbs. What is your take on this vs the Porsche claimed curb weight of 2955 lbs?
Old 08-23-2015, 04:15 PM
4carl
4carl's Avatar
Originally Posted by Rob VN
Carl,
Thanks,
Rob
Rob,that's the head of the bolt not the nut. I checked the camber f-1.5 both sides,r-1.3&-1.4. Waiting for the suspension to settle to do the toe and thrust.
To reduce unedsteer you can increase the f camber and or stiffen the rear bar or soften the front. What most people don't know is you don't have to change both sides of the bars.You can get a finer adjustment by only moving one link stiffer. So in essence a 3 way adjustable bar is really a 6 way. Carl
Old 08-23-2015, 08:02 PM
sunnyr
sunnyr's Avatar
PCCB is ~40lbs lighter (link) than steel.
Factory Li-ion battery option is ~30lbs lighter than standard battery.
Not sure how much the LWB is compared to standard seats. The old GT2 buckets were ~32 lbs lighter (link). The new LWB has electric height adjustment, so it is probably not as light. But since GT2 seats is still an option in Europe, Porsche could have used that to rate the car. So it should be possible to drop ~100lbs while still keeping AC/Radio, at least in Europe.
Old 08-23-2015, 08:27 PM
Rob VN
Rob VN's Avatar
Default OK on Bolt head
OK on the bolt head Carl.
That is pretty cool to stagger the sway bar settings. I always thought they were to be kept "even".
Did Andreas leave us any easy to use suspension center line marks or fasteners for thrust measurements?
Old 08-23-2015, 08:44 PM
4carl
4carl's Avatar
Rob,when you change the setting all your doing is changing the force it takes to twist the bar. So by changing one side you are just making smaller adjustments. i cant remember where i learned it(not fun getting old) but it works really well. Here's how you set and measure thrust.
http://lshapedgarage.blogspot.com/20...asurement.html
carl
Old 08-23-2015, 08:49 PM
sonorous
sonorous's Avatar
The GT4 wheels are also flow formed
How did you determine they were flow formed and not forged as was quoted in the original video with AP? Just curious...
Old 08-23-2015, 08:54 PM
DeerHunter
DeerHunter's Avatar
The GT4 wheels are also flow formed and are 8.5&11" wide plus wider tires 245 &295s. carl
I thought I read the GT4 wheels are forged. Am I mis-remembering?
Old 08-23-2015, 09:15 PM
vantage
vantage's Avatar
Agreed, I personally do not think the A/C delete is worth the inconvenience on a car as luxuriously appointed as the GT4, but then again we live in SoCal.
Old 08-23-2015, 09:25 PM
RealityGT
RealityGT's Avatar
AP Def said that the wheels were Forged for weight savings.. The weights posted in another thread would confirm this.
Old 08-23-2015, 11:31 PM
4carl
4carl's Avatar
Its a joke no way in hell ! My car is 3083 stock manual seats stl brakes 1/2 extd tank..i even took out the owners manual from the glove box..carl
Old 08-23-2015, 11:41 PM
4carl
4carl's Avatar
Wheel enhancement told me they were flow formed, for whatever thats worth? But they may be wrong. They weigh a little more than the Carrera 20s that are flow formed. The C20s are 8 & 9.5" wide with 235 & 265s VS 8.5 & 11" with 245 & 295s. Flow formed wheels are lighter than cast but heaver than forged. True forged wheels are really expensive. carl
Quick Reply: True GT4 weight and suspension info.
