981 GT4 battery is H5 AGM not H8 AGM - Clear "Steering support restrictive"
Happy Father's day.
My battery died and I went buy a new battery. Both AutoZone and Advanced Auto database say the car battery is H8 AGM.
I bought one , took it home only to discover that it was way too big.
Long story short, I measured the battery dimension, it is actually H5 AGM.
So, save yourself time, make sure you order H5 AGM.
Replacing the battery is simple.
Remove the two screws from the tire inflator housing.
Remove one bolt that holds the bottom bracket
Remove two nuts that hold the top bracket.
There will be error message "Steering Support Restrictive ..." upon starting the car since the battery was removed.
Just turn the steering wheel lock to lock , it will reset itself.
The following 5 users liked this post by MasterApex:
GT4 FUN (06-21-2020),
HelpMeHelpU (10-04-2022),
Jim Cobb (06-15-2021),
Space Coast GT3 (06-22-2020),
weekndr.porsche (06-21-2020)
I'm way late here, @MasterApex, but can you tell me in what dimension the H8 was too large? Was it too wide? If so, I noticed the same problem, but there was plenty of room to fit it, and I thought there may be value in buying a larger battery since my first battery didn't last very long...
Only issue was that there was one bolt on the floor of the housing for the battery I had to remove. As far as I could tell, that bolt wasn't serving a very important purpose (and it's been over a year now), but would still be curious to know if I made a booboo that I'll pay for with lost chassis rigidity at the track or something, hah.
Also curious if anyone knows anything about us needing to go to the dealership to have certain settings reset when replacing the battery...?
Location: On a pygmy pony over by the dental floss bush
RocketGuy3 (03-18-2021)
Has anyone found an oem equivalent that is around the same weight or slightly lighter? All the agm’s at auto parts stores I found are huge at 60lbs. I believe oem is about 40lbs. I know antigravity makes very light ones, but I was hoping not to spend that much.
Premium Sponsor
Best regards,
Chad
chad@antigravitybatteries.com
DFI (12-25-2021)
Hi Manny, if if's something you might be a little on the fence with in regards to price I just wanted to let you know we'll be having a sale on the automotive line coming over Black Friday. If not, completely understand but just wanted to be sure and mention.
Best regards,
Chad
Best regards,
Chad
Antigravity (11-10-2020)
Best regards,
Chad
Best regards,
Chad
Premium Sponsor
If you hook up a battery charger or maintainer to the battery terminals while you change the battery, the car doesn't know the battery has been removed and nothing is lost. Make sure you don't touch the hot (+) to ground and short it out, you should be good to go.
Best regards,
Chad
Best regards,
Chad
Bummer, it seems I jumped the gun. I just ordered a 30amp H6 from you on Sunday
And congrats on your wong!
I've disconnected the battery on my car without adding any power supply to keep the car powered at least a dozen times if not twenty times. Never had a problem with anything not being as normal after reconnecting other than doing the power window reset by selecting up again once the window is all the way up and down again when it is all the way down.
I think with PIWIS you can reset the aging parameters for the battery that are calculated within the ECU. Don't know what that affects or helps with, but I believe that is the only thing PIWIS could possibly be needed for when replacing a battery.
IDK about a GT4 but on a 2016 Spyder (981), an H8 will fit. The single bracket that holds the bottom of the battery has to be moved to the far end of driver's (left hand driver) side but there was a drilled and tapped hole for it.
However, I opted to replace with H5 (OEM size) as I didn't want the extra weight and don't need the extra amps as I don't drive it when it's less than 50 degrees outside.
I hook up a 12 VDC lantern battery to the jumper points in the driver's side fuse box and have retained settings.
