Clubsport “low maintenance”?
Is the 992 GT3 Cup similarly low maintenance?
assuming that was a serious question, i believe the answer is "NO" (or not even close). There are many in other threads of the forum that can give you a clue as to running costs of running a Cup car.
mikew968 (02-23-2022)
Admittedly, my search skills isn’t great. My quick search didn’t get me to specifics yet.
What makes the GT3 Cup a lot more expensive to run? Remember, I am talking about mellow driving of the car during private track days. Same engine, similar transmission, similar suspension, no?
A race team, I understand the higher the tier, cost increase super linearly.
Upon a bit of digging, is the 992 GT3 Cup synthetic fuel only? If so, I now understand one aspect of significantly higher running cost.
I'm sure it is not. Porsches project in South America to produce such fuel is not started. Historically, the largest difference for Cup is the recommended rebuild schedule for the transmission and engine. Just my 2c but why don't you pick up a used 718 GT4 Clubsport and get going while waiting for a RS CS?
^^ that is good advice.
Good recommendation and question. I’m timing it with the opening of a new track with track side storage facility. Plus, I like the extra excitement of new toys and knowing the full history first hand.
“mellow driving” LOLz.
Thanks. Looks like 992 GT3 Cup is 60 hours for transmission inspection and 120 hours for rebuild. Engine is 100 hours for both cars. Since it’ll be mellow driving, I’d expect I can stretch it longer (after a cycle at the recommended interval to discover actual wear).
Jamaica2G (10-28-2023)
Expensive service, parts, and labor are expected. I mostly want to see if I can expect a prepared car, drive “mellow” for the day without a crew.
I would be lucky to get 2 hours on the car per day. That’s 30 days until transmission inspection. Tires, brakes, pre & post track inspections aren’t concerning.
Hope this helps convey what I am after and expecting.
ForeverCar...Cup cars are like shifter karts they don't like to be run Mellow. They need to be in a certain manner, shifted at a certain RPM range etc. Plus a cup car can and will bite you a lot easier for a mistake than something like a GT4. The slower the car to start with the faster a driver you will become.
Jerrym (02-23-2022)
I appreciate the feedback. Realistic in terms of cost or needing a full crew?
Basic Site Sponsor
Basic Site Sponsor
Received 3,220 Likes
+1 on the difficulty of safely performing "mello" laps on a purpose-built, high-level GT car like a 992 GT3 Cup. Just talking from a driving perspective.
The more high strung a GT car is (cams, compression, throttle mapping, racing brake pads, rotors and hydraulic ratios, gearing, general lack of suspension compliance, not to mention slicks, real ones), the more it needs to be driven with enough controlled aggression, almost violence, compared to what most track day drivers are used to, JUST in order to get the tire temps, brake temps, traction and transitional handling up to a level that ensures predictable behavior.
Not saying an enthusiast jumping in the deep end with one of these couldn't go very easy, just saying it wouldn't be very much fun, and it would entail some risk on-track. Now, get GOING and the car comes alive and actually drives better, with more predictible grip and braking power. Smoother, too.
The GT4 level cars (specifically the 981 and 718 GT4 ClubSports, less so for the RS ClubSport) are much more accommodating of the kind of casual use, even up to what most amateur drivers would consider significant pace, that they're likely to see at track days, club days and DE use. Definitely lower maintenance and longer intervals between component lifing. Even though the 981 GT4 CS series are getting on in years, they still hold up well.
As pointed out, the GT4 car is a great training ground for the "big" car, which is basically a GT3 (worldwide specification) one make car without BoP restrictions.
I see a fair number of self-maintained (at the track, sent to shops periodically) GT4 cars and a few previous gen GT3 Cups at the track. David, Erez and Kevin go (or will go) to the track with minimal support and on their own in their 992 GT3 Cups, but all three have some significant experience in street/factory-built racing Porsches, and all three of their cars will spend many more hours on the car in the garage or shop for every hour they're on track.
Good luck!
Good luck!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
