Data and video options for the 718 GT4 Clubsport
Basic Site Sponsor
Basic Site Sponsor
Received 2,973 Likes
Made a little video featuring several different options for good video, or video plus data, for the 718 GT4 CS.
Plus, pics at the bottom from a brand new 718 GT4 CS installation twenty minutes from my home.
DM me if I can help.
View out the front! In car view top left.
Forward facing camera high in the center of the windshield.
Camera 2 over the driver's right shoulder, or you can face it back.
HD2 unit on the center tunnel, completely automated.
Car connection, Porsche makes it easy!
Best place for the antenna.
Let me know if I can help.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
whats the difference between the VBOX HD2 and the VBOX HD2 HDMI?
Good stuff Peter! I went with the Solo DL2 and SM HD2 for what I am doing. I would also point out that AIM has a very extensive map written for the 718 GT4 that pulls pretty much EVERYTHING the car logs into the AIM system. I use Track Attack ($8 per month) for data integration, it allows some things that the AIM software cannot do.
AH the Eye tallions.....
Stay safe!!
Chris
Stay safe!!
Chris
ProCoach (03-25-2021)
Basic Site Sponsor
Basic Site Sponsor
The difference is that the V5 version of the HD2 is the standard 60 FPS capable system and the V6 version of the HD2 includes an additional output board and a locking HDMI port to stream not only video from individual camera, but also all the data overlay rendered on the video.
The price difference is $270 more for the HDMI output unit. The V1 (30 FPS) and V5 (60 FPS) standard units are not able to be updated, additional hardware in the unit is required.
This is the ONLY system that is capable of streaming data rendered onto the video in real time. Most popular place I've sold these is Ferrari Challenge and WRL Endurance Racing.
The two best streaming solutions that I have used are the LiveU Solo with two cell modems and the unlimited data plan, $1450 hardware, about $3K annually for the bonding (sending the signal together for the best quality and least latency) INCLUDING an unlimited data for BOTH ATT and Verizon, and a combination of the Cerevo LiveShell X with a Cradlepoint or Pepwave dual-SIM modem, the latter not much less expensive for the hardware, use or buy your own plan.
Basic Site Sponsor
Basic Site Sponsor
AiM Channel List for the 718 GT4 CS through the Solo 2 DL, over fifty channels:
Engine RPM
Gear
Vehicle speed
Front left wheel speed
Front right wheel speed
Rear left wheel speed
Rear right wheel speed
Longitudinal accelerometer
Lateral accelerometer
Yaw rate
Water temperature
Ambient temperature
Oil temperature
Intake air temperature
Gearbox temperature - clutch
Gearbox temperature
TPMS Temp FL Front right wheel temperature (TPMS)
TPMS Temp FR Front right wheel temperature (TPMS)
TPMS Temp RL Rear left wheel temperature (TPMS)
TPMS Temp RR Rear right wheel temperature (TPMS)
Oil pressure
Brake pressure
Fuel pressure
Manifold air pressure
Ambient pressure
TPMS Press FL Front left wheel pressure (TPMS)
TPMS Press FR Front right wheel pressure (TPMS)
TPMS Press RL Rear left wheel pressure (TPMS)
TPMS Press RR Rear right wheel pressure (TPMS)
OOil level
Steering angle position
Camshaft inlet right
Ignition advance
Camshaft inlet left
Throttle pedal position
Throttle position sensor
Travelled distance
Battery voltage
Fuel level
Lambda right
Lambda left
Engine torque
Engine torque demand
ABS Position
Malfunctioning indicator lamp
Traction Control off (PSM)
Paddles downshift status
Paddles upshift status
Brake bias
Brake switch
Electronic stability control off (PSM)
Gear lever position
Racelogic Video VBOX channel list, nearly forty channels:
ABS Switch Position
Accelerator Pedal Position %
Battery Voltage V
Brake Bias
Brake Light on/off
Brake Pressure bar
Coolant Temperature °C
Engine Speed rpm
Fuel Level L
Fuel Pressure bar
Gear
Gear Down
Gear Switch
Gear Up
Gearbox Oil Temperature °C
Indicated Lateral Acceleration g
Indicated Longitudinal Acceleration m/s
Indicated Vehicle Speed km/h
Intake Air Temperature °C
Manifold Pressure mbar
Oil Pressure bar
Oil Temperature °C
Steering Angle
Steering Direction
Throttle Position %
Traction Control Mode on/off
Tyre Pressure FL bar
Tyre Pressure FR bar
Tyre Pressure RL bar
Tyre Pressure RR bar
Tyre Temperature FL °C
Tyre Temperature FR °C
Tyre Temperature RL °C
Tyre Temperature RR °C
Wheel Speed FL km/h
Wheel Speed FR km/h
Wheel Speed RL km/h
Wheel Speed RR km/h
Yaw Rate °/s
The AiM is more user friendly than the Cosworth, the VBOX is MUCH more user friendly than both.
Engine RPM
Gear
Vehicle speed
Yaw rate
Water temperature
Ambient temperature
Oil temperature
Gearbox temperature
Oil pressure
Brake pressure
Fuel pressure
Ambient pressure
OOil level
Ignition advance
Camshaft inlet left
Travelled distance
Battery voltage
Fuel level
Lambda right
Lambda left
Engine torque
ABS Position
Brake bias
Brake switch
Gear lever position
ABS Switch Position
Battery Voltage V
Brake Bias
Brake Light on/off
Brake Pressure bar
Engine Speed rpm
Fuel Level L
Fuel Pressure bar
Gear
Gear Down
Gear Switch
Gear Up
Oil Pressure bar
Oil Temperature °C
Steering Angle
Steering Direction
Throttle Position %
Wheel Speed FL km/h
Wheel Speed FR km/h
Wheel Speed RL km/h
Wheel Speed RR km/h
Yaw Rate °/s
Basic Site Sponsor
Basic Site Sponsor
I’ll look at some data Tuesday from a 718 GT4 CS.
I have, in the past, changed units of measure in the scene configuration of other cars. Will report back.
Speeds, G’s and distance are all easily changed in the analysis software.
I think so. Racelogic is saying that the units of measure coming from the car are metric.
Basic Site Sponsor
Basic Site Sponsor
I have only 991 GT3 R and 992 GT3 Cup VBOX data that I actually analyze for people and it is in the factory measures. Have not worked with a car with an ICD with changes measures, but I think that’s just a conversion for the display.
Will report back. Like AiM, it’s usually going to display in analysis the channel measures selected in the configuration. It’s so common for me to work with brake pressure in bar that honestly, I’ve never asked that question, myself.
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Please email me if interested. I don't always check the forums.
Basic Site Sponsor
Basic Site Sponsor
VBOX Video HD2 V5 units now available 8/20/21
After pausing production in late April due to supply chain constraints, I have begun receiving restarted production of the VBOX Video HD2 V5 two-camera track kits.
The HDMI streaming capable version, the V6, is still waiting on board components and expected to be available in mid-September.
There is a small price increase scheduled to go into effect 9/1/21 but I can offer new units at the current prices as long as my current stock lasts.
This system is used by Porsche for all record runs, is now in most cars at the PDX at Barber Motorsports Park and is mandated in all Porsche Carrera Cup and Super Cup competition worldwide.
This is an extremely popular kit for 996 MkII on, 997, 987, 981, 991 DE cars as well as 991/992 GT3 Cup, 991 GT2 RS CS and both 981 GT4 CS and 718 GT4 CS track and racing cars.
I’ve sold more than five hundred in the last five years and it’s the only system that works natively with Mac OS and iOS devices, as well as Windows.
Please DM or email me, if interested.
