E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old Dec 8, 2013 | 11:58 AM
  #1621
JustinL's Avatar
JustinL
I was going to ask about a time change for the Wednesday night. Is everyone happy when it is now? I don't think we can go any earlier, but we could push it half an hour or an hour later. We're trying to keep it reasonable for the whole continent, which is tough.
Old Dec 8, 2013 | 12:06 PM
  #1622
Indy Rev's Avatar
Indy Rev
I could go later. I wouldn't push it beyond an hour, but starting at 8 or 8:30 would be nice.
Old Dec 8, 2013 | 12:45 PM
  #1623
ny991's Avatar
ny991
Starting at 8 is fine with me, especially if it gets a few more out there with us.
Jack
Old Dec 8, 2013 | 01:59 PM
  #1624
HoBoJoe's Avatar
HoBoJoe
I'm fine with the time changes, I'm sure we'll have to make some adjustments with the Holidays.
Old Dec 8, 2013 | 04:18 PM
  #1625
tasracer's Avatar
tasracer
7-9 works for me
Any update on the RUF?
How bout everyone running a fixed setup?
Old Dec 8, 2013 | 06:29 PM
  #1626
HoBoJoe's Avatar
HoBoJoe
Does the McLaren have an iracing base setup for Road America? I tried running James' some in practice and I couldn't keep it on the road. I used a setup I got from the forums, adjusted the spring perches because the weight lowered the car too much, and adjusted the differential lock.
Right now everyone shares their setups which I really like. I'm not so good with setups so I like trying a few that work for others to see what suits my skill level.
Old Dec 8, 2013 | 06:44 PM
  #1627
Indy Rev's Avatar
Indy Rev
Yes there is a base setup for the MP4 at RA. I have a decent setup ill share tonight.
Old Dec 8, 2013 | 06:47 PM
  #1628
HoBoJoe's Avatar
HoBoJoe
Sounds good. I pulled a few off the forums, if I get one to work for me I'll share it out. Usually the iracing base setups are neutral which is good for us new guys.
Old Dec 8, 2013 | 07:44 PM
  #1629
HoBoJoe's Avatar
HoBoJoe
Is the password still spyder? I'm getting a credential failed message when I try to join.
Old Dec 8, 2013 | 08:03 PM
  #1630
HoBoJoe's Avatar
HoBoJoe
I got in, I think I did all caps first, then I had to log out of the service and back in.
Old Dec 9, 2013 | 11:18 AM
  #1631
HoBoJoe's Avatar
HoBoJoe
My pedals are about to give up the ghost. Every other lap I lose the last 20% of my braking, I have to unplug/replug the pedals a few times and eventually they start working again. I'm going to try and find a solution or just brake WAY early this week. Santa is bringing me a set of the CSR Elites, but that's 2 weeks away!
Old Dec 9, 2013 | 11:27 AM
  #1632
Indy Rev's Avatar
Indy Rev
That sucks. Use the time to really hit those apexes. Slow is fast
You will love the CSR pedals. They helped a ton with my braking and throttle control.
Old Dec 9, 2013 | 02:44 PM
  #1633
JustinL's Avatar
JustinL
I think the 18th will be the last one before we take a break for the holidays. We'll start back up on the 8th of January. Maybe then we will push the time half an hour later for the west coast people. If the RUF is out early, we'll all have lots of time to come to grips with it before the first race.
As far as the setups, the stock setups are pretty good, but I think we need to run open setups to compensate for weather. I always start with the base setup for the track and tweak the sway bars and brake balance. That's usually enough to make them run well. Let's see how things work when we get the RUF.
Old Dec 9, 2013 | 03:06 PM
  #1634
User 52121's Avatar
User 52121
I've basically been doing the same - even less, I don't mess with the bars, usually. Just select the iRacing "fixed" setup for the track (or for a track that's similar), bump the bias towards the rear a bit, and go.
At Road America I also took a bunch of wing out of the Ford. The McL has more top speed and the default setting had me down a few mph in the Ford by comparison.
Good to meet up with you guys for a bit yesterday. I actually had some time to kill and was just cruising around on RL here and bumped into this thread again. Managed to get on for ~20 minutes or so.
As for pushing it later - that's fine by me. Getting on with the current timing is usually tight. I don't get home from work until 7:30-7:45 Central time. Gives me enough time to say hello to the wife and get the rig fired up. Usually get 1, maybe 2, full laps in under qualifying before the race starts...
Old Dec 11, 2013 | 04:18 PM
  #1635
loxner's Avatar
loxner
So is it Road America tonight?
