"Failed Tech" iRacing
I'm playing around with the IMS oval and I can run a Pro FM or the Dallara IR-05.
When I try to drive the Dallara DW12 I get "failed tech" when I load the sim. Any idea why? This car works on every other track I have.
Don't know that i've ever gotten a failed tech message. I do have to reset the wheel/pedals every so often since it fails to recognize them randomly.
Searching some reddit posts it looks like the baseline setups can sometimes be "off" on certain tracks/previous patches. If you check the setup it may indicate what setting is causing the failure.
When I went under Garage and then Chassis, all of the failed settings were flashing. I paralleled some of the setting from IR-05 and was allowed to tech. The car still needs chassis setup but it’s driveable.
The garage setup page will highlight in red what is out of spec..
Coochas (05-23-2024)
Likely loaded your last (road course) setup. I haven't run that Dallara or ovals, but there are probably preset, fixed setups for that car + oval available? Load one of those.
Coochas (06-01-2024)
