AIM Math Channels - Lap Integral
Help !! I am looking to calculate tires loads over a particular lap with AIM math channels. For that I have shock pods, know the spring rate and with a math channel can correlate the shock pod displacement with actual height changes which allows me to calculate actual downforce changes per wheel.
What I am now looking to do is calculate the total dynamic load per wheel per lap, however I am only looking to calculate the integral over the positive values load values (negative load values correspond to unloading of the particular wheel). The lap_integ function in AIM just takes all of the positive and negative values into account over a lap and I would like for it to consider the positive values only.
Thoughts?
Thoughts?
Rennlist Hoonigan
which cost no drachmas
Thoughts?
Thoughts?
lap_integ(IF(LT(shock pot,0.001),shock pot,0))
Rennlist Hoonigan
I think you have 2 problems. First, your math is making really small numbers, so they don't display right. Second, you have a parenthesis problem. I broke it into 2 channels.
Load
(RR_Shock_Senso+0.4)/(25.4*700)*1000000
Integral
lap_integ(IF(GT(load, .001),load,0))
This works once you put in multiply by 1000000. Without that, the values are too small. The integral gives you a sum total of the values. If you do a channel report and take the maximum, it will give it to you for each lap.
Load
Integral
Thanks! Let me try that out. Will report back!
Thank you - got it to work. This chart now shows the dynamic loading differential (front left tire) at Watkins Glen between my old car and my new car - a massive difference about 73% higher! The new car accelerates a little faster and I've learnt to brake a little better, not lift in the Esses and cary higher min speeds
Fast car. I saw 148.3 MPH. I got a total of about 5 clear laps. My fastest laps were all balked by someone or something.. (double yellows) Congrats on your very fast weekend.
Chris
Chris
Chris
Chris
Basic Site Sponsor
Basic Site Sponsor
Received 2,836 Likes
^^Bingo^^ Much higher than the average vMin for most cars.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
