Tpms setting?
Im setting up my remote tpms sensors in my mlx2. I want the screen to flash white when the tire temp is warmed up but i dont know what is a good warm temp. Running a nt-01 on a 6-gt3 car. Im also figuring ill pick the right rear for the alert. Any better way to set up the alert?
thx,
Aaron
edit: i figured out how to light the leds so im gonna use 4 of them to light up geen, 1 for each corner.
thx,
Aaron
Basic Site Sponsor
Basic Site Sponsor
Received 3,270 Likes
160-165 is the bottom end.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Thx coach
Rennlist Hoonigan
which cost no drachmas
The TPMS temp is the air temp in the tire, not the surface temp. The 165 Pete refers to is would be a surface temp, not air temp.
The temp number you have is for calculating build and hot/cold pressures. IMHO, it's not good for seeing if the tires are hot. Use pressure to see what the tires are doing. For temps, you need to have e IR sensors, not TPMS temps.
ProCoach (03-23-2023)
Well thats disappointing....IR sensors r not in the budget this year.
I built some math channels using ambient temp and 50* offset and then im going to compare it to the temp to give me a blue or green led so i can use it as a general rule. Of course ill have the test the offset to see if im close. I also built some display screens for the tmps temp and pressure so u can monitor it.
I wouldn't waste my time with tire temps off the sensor. I haven't found that useful at all. I also run IR sensors which are the cat's meow. Make sure you set a low tire pressure warning though and don't get too fixated on your actual live pressures.
It takes about 5 laps on most tracks to get to target pressures. You can be up to target tire surface temps in 2 laps.
The following 2 users liked this post by Frank 993 C4S:
Matt Romanowski (03-25-2023),
ProCoach (03-25-2023)
Thx for the advice. I can usually feel the tires getting sticky but was looking for some validation. I have tire temps and pressures set up on other screen windows to view when i get back into the paddock. I dont plan on veiwing the actual values while driving. I guess ill budget for ir sensors next year.
Alarms r already set up....i lost 2 tires last year, 1 corded and the other got a large screw in it while on track. Not a fun experience and pressure warnings would have helped. I have them flashjng the screen red at 25 psi.
I view the IR temps and pressures on secondary screens during the outlap so I understand my tire condition before the green flies. It also allows you to judge what tire warming techniques are most effective. I monitor the IR sensors actively during rain races in an effort to keep heat in my rain tires. Likewise, during drying conditions, I use the IR sensors to make sure that my rain tires do not overheat. We primarily us the IR sensors for chassis tuning - great tool! If you are planning to use the AIM IR sensors, they are great and easy to install, but they are prone to being hit by rocks. I lose one at least every other race weekend, sometimes more often.
