Micro scratch/spider web removal??
I have some mild scratches-spider webbing on my guards red 928....otherwise the paint is in very good shape..... Nothing too deep....just the type you can see under florescent light, or from the right angle. I am looking for a polish that will remove-minimize the scratches or a glaze that will fill them (but also withstand a wax coat after it like rejex) I don't want anything too abrasive, since I don't want to remove too much paint? I also want something that isn't too hard to remove
I use a random orbit buffer (1K rpm) with microfiber bonnets....I use a non abrasive chemical oxidation remover to keep the paint fresh...but want something to help on the little scratches...
Ideas? Heres a pic (hard to show scratches)
Originally Posted by jb26jb
I'd try optimum polish but you have to kick up the speed on the random orbit assuming its a Porter cable to like 4 finishing with 6
I've been thinking about getting a portercable....since its adjustable speed, 6" pads and far lighter!!
You seem to be describing a GEM orbital. They were designed for plane polishing and not so much for cars...hence the heavy weight.
You should get a PC or Cyclo as your orbital won't do anything when used in conjunction with a polish. In fact it may cause more marring than it removes.
When you get a PC or better a Cyclo, Optimum Hyper Compound followed by Optimum Polish should remove 90% of the marring.
ANthony
ANthony
ANthony
ANthony
The good news is it should be easy to remove the scratches, since guards red is a base color only paint..... Time to get a new polisher!! Which porter cable do you like...the 7424 or 7336? Whats the difference?
I use a PC with a Swirlbuster pad from Sonus - works well with their SFX2 swirl removal polish.
I bought a black C2 and had some work to do, removing the swirls from the previous owners detailing attemps - the above with a suitable final wax did the job with ease.
http://www.autopia-carcare.com/sonsbfpp.html
http://www.autopia-carcare.com/son-420.html
http://www.autopia-carcare.com/pcdepot.html
Chris.
Chris.
Originally Posted by IcemanG17
I looked on the buffer but don't see any brand names...its a big two handle, all metal in a dark gray color with a pebbly texture...huge motor and weight assembly with a green SOS looking foam pad under the bonnets?
As for the PC.....this is a nice deal here http://www.autogeek.net/optimum-porter-cable-kit.html
Let me know when you decide and I can help you through the steps.
Anthony
Under the Lift
Brian:
I missed this thread earlier. I have a Porter Cable and a variety of mild compounds. My favorite mild finishing compound for removing the fine spider web lines is 3M Finesse-It II. It is a very fine aluminum oxide liquid that dissolves to nothing as you buff. The only problem is the 1980s paint on the 928 is hard as a rock and takes a lot of buffing to clear up. One of these times when you visit, let's try the PC with this compound.
Originally Posted by texas911
Can you buff out spider cracking? My 993 has a small crack on the roof. Hope it won't spread. Is there a way to get rid of it?
If it is a light scratch where your nail does not catch then it is possible it can be corrected with the right product, pad and polisher. Is it possible to post up a picture?
Anthony
I bought a Porter Cable for $ 110 and then had to buy the Velcro attachment for my pads. Here's the link Iwhere I found mine.
http://portercable.cpoworkshop.com/r...ers/7424r.html
Also, I just used it for the first time on my old truck. I used #4 and tried out #5 with Griot's paint sealant. How hard do you need to puch down? I know it's a feel, but I am tempting on washing and buffing my 930 tomorrow.
Thank you.
Thank you.
