Air Suspension squeaks when entering vehicle
Hi, I noticed after say 24-48hrs of my car sitting idle, when I or people get in the backseat - there is a proper noticeable suspension creaking noise pops up, mostly from the rear suspensions. I have the Air suspensions with rear axle steering, does anybody noticed it in yours? Car is 3 months old MY23 e hybrid and I am not sure if its relevant but I live next to the sea coast line and my driveway is open (no garage).
I have an appointment booked with my local porsche dealer for the cabin rattle and this suspension squeaking sound.
Needsdecaf (04-14-2023)
Same issue, same specs, and the dealer said they didn’t notice it while testing. Pls let us know what happens with your dealer. Thanks
sometimes it happens several times a day, sometimes it doesn’t happen for few days. I use my car daily and I noticed it only when getting into the car while switched off. Sounds like two pieces of metal hitting each other
Sounds exactly same. I get it mostly from the rear suspensions. Is yours coming from both front and rear? My car is due to be checked at dealer on 27th Apr. i will keep you updated the outcome.
Pls keep us updated, sounds like a common issue!
I tested this tonight my in S with air suspension, after about 2 hours since driving. No squeak. I will try it tomorrow after 12 hours since driving.
Due to the harsh winters I get, road salt, sand and dirt are used on New England Roads in the winter as well as a brine solution before winter storms start ...
What I do is raise the system to the highest setting. Then rinse the underside of the front and rear, use a fairly high-pressure nozzle on your garden hose or 1000-1500 power washer ( mine is electric), rinse all 4-Air springs ( I also use a small ( size of your hand) soft bristle brush to clean off the sand off the rubber airbags as best that I can , all bushings, all ball joints, steering arms, anti-roll bar bushings, mounts, sway bar links, upper and lower control arms, and bushings. Then spray all 4 with a foamer gun, get the soap in there and let it sit for 10-15 mins, and neutralize the salt and brine on the rubber components.. rinse off again as best you can...
Then... Go for a drive 15-20 mins highway speeds to dry it all off...
Then get some RV rubber conditioner and spray everything ... air springs, control arm bushings, anti-roll bar bushings, etc etc Just a light coating will be fine! you don't need to soak them where it's dripping everywhere and on your garage floor.
( you can also walk into most Walmart stores and find this , if you don't want to wait for amazon to deliver)
The following 2 users liked this post by cwazyeurodrivr:
rajatparihar (04-16-2023),
Turrrbo (04-17-2023)
Did the test again today after 12+ hours of no driving. Result: no squeaks.
