Sponsored By:
Sponsored By:
GTS Tune
Old 03-28-2023, 10:06 AM
Turbo-X2
Turbo-X2's Avatar
Originally Posted by mrjbb7
To revive this thread, I’ve got a MY22 cayenne GTS, looked a t few tunes and considered APR. Ultimately for $290 I purchased Pedal Commander which remaps your car’s throttle response which most tunes do as well while also adjusting many other parameters.
The Pedal Commander has significantly reduced the turbo lag and dramatically increased throttle response. The car absolutely feels perfect now: it commands the power it’s supposed to be utilizing IMO much quicker. It’s smoother more powerful and overall much quicker. All without adding more horsepower and adjusting fuel, air and other other engine parameters that could cause additional issues.
Just thought I’d add to this thread as this is a viable alternative IMO. Ask any questions.
Careful with that pedal commander, I had one installed and had to remove it because sometimes, not all the time my throttle would not respond and when making u turns or when I need to go it hesitated which is super dangerous. I also have the COBB tune now and you would not believe how much the car wakes up. If you experience any hesitation with the throttle remove that piece of junk pedal commander immediately. I even had them replace the first one I had and the second one did the same exact thing.
Old 03-28-2023, 10:11 AM
mrjbb7
mrjbb7's Avatar
Sheesh that’s good to know. Will monitor carefully for the next day or so. Might end up with a tune after all!!
Turbo-X2 (03-28-2023)
Old 03-28-2023, 10:17 AM
Turbo-X2
Turbo-X2's Avatar
Let me know if you experience any of that, I'd say about once every day of normal driving it would happen. I like the pedal commander when it works correctly as I have had them in all my previous cars and never had an issue. Maybe they corrected the problem.
Old 03-28-2023, 10:21 AM
mrjbb7
mrjbb7's Avatar
I’ll definitely let you know! I appreciate you coming on here and offering this insight. I’ve had it on a few other cars and it’s worked great. Im hoping that with your complaint they were able to create an update that fixed that issue.
But I may just decide to not keep it and opt for a tune. I can’t afford for it not to work properly when I usually have my family with me.
Old 03-28-2023, 10:18 PM
cjspeed
cjspeed's Avatar
Originally Posted by Selpo
Cobb has it available now for 2022 GTS, search for their thread, pretty impressive gains… I am waiting for them to come out for 2023
Ah, so the 22s are completely different than the 23s I guess? I saw a social post the other day with a 22 that was tuned from APR and thought maybe its the same maps for the 23. I'm ready for more power and so is the GTS.
I wonder if the tune will provide any more snap crackle pop. My most favorite thing about the GTS is whenever I start it in the garage during idle every 10 sec or so you get those additional pops on top of the grumble.
Old 03-29-2023, 01:09 AM
drcollie
drcollie's Avatar
Received 4,323 Likes on 1,510 Posts
Pedal Commanders do not make a vehicle quicker. They are simply an electronic by-pass to decrease delay in fly-by-wire throttle response. You have the illusion you are going faster and quicker, but in reality all it does is shorten the factory-programmed response time so the vehicle responds to the throttle input rate more rapidly. This can be a good thing or a bad thing. Good when you want to jump off at a stop light, bad when your wife is trying to park the vehicle at the grocery store. Be careful of them ( I have one installed in my wife's Macans S) because they really are Jekyll and Hyde. 1
Looking for 600 hp from a 453 HP GTS? Remember that Porsche uses a special lightweight transmission in the GTS series that is not the same one in the Turbo or Turbo S. Can it handle 600 hp? Maybe, maybe not. Expensive to replace while you try to figure that out.
The following 2 users liked this post by drcollie:
911dude41 (03-29-2023), mrjbb7 (03-30-2023)
Old 03-29-2023, 12:11 PM
Oldboy52
Oldboy52's Avatar
What about transmissions in base and S trims? Are they the same as the GTS or Turbo or yet another version? Thanks in advance. Lou
Old 03-29-2023, 02:11 PM
SARGEPUG
SARGEPUG's Avatar
When you say chipped do you mean a piggyback or are you looking for an actual ECU tune? I've explored both routes and right now there is nothing else but Racechip for my 2022 Cayenne GTS. I'd rather not do the Racechip but have looked into APR ECU tune and JB4 piggyback - both of which are not available at the moment for a GTS. What spec of Cayenne are you getting?
I have a '21 GTS coupe, does this compromise your warranty??
Old 03-29-2023, 04:29 PM
drcollie
drcollie's Avatar
It can and will, if tied to the modification.
Old 03-30-2023, 08:59 AM
ACowabunga
ACowabunga's Avatar
It would appear as though the transmissions are different for the GTS/Turbo compared to the base or S trimlines.
The transmission part number for the Turbo is: 0FE-300-036-J
The transmission part number for the S is: 0FE-300-035-N
The transmission part number for the base is: 0FE-300-035-J
Oldboy52 (03-30-2023)
Old 03-30-2023, 09:34 AM
bobblehead
bobblehead's Avatar
^ Base uses 0FE-300-036-G (as the 035-J has been discontinued)
Old 03-30-2023, 09:38 AM
drcollie
drcollie's Avatar
There was a long thread on this topic back in 2021. Read it here. Will help you decide on tunes and possible side effects of doing too much.
https://rennlist.com/forums/cayenne-...otorsport.html
mrjbb7 (03-30-2023), Oldboy52 (03-30-2023)
Old 03-30-2023, 09:40 AM
ACowabunga
ACowabunga's Avatar
Thanks @bobblehead for the update!
Old 03-30-2023, 03:26 PM
SARGEPUG
SARGEPUG's Avatar
That rules it out for me! Wayyyyyyyy to much exposure....
Old 03-30-2023, 04:02 PM
23109vc
23109vc's Avatar
I’m in the same boat. My 2021 GTS is plenty fast and fun… more power would be great, but I don’t want to be the unlucky one who happens to have a legitimate defect in a motor/transmission that WOULD have happened ANYWAY…but b/c I happened to have a tune, all warranty coverage is denied. That is a lot of exposure on a car like this.
I can imagine a new motor is $30k+ in parts and labor….
But it sure would be fun!!
if only Porsche woudl offer a “factory” tune option….
SARGEPUG (04-05-2023)
Quick Reply: GTS Tune
