Any weaknesses on the V6?
Hello folks!
Just curious, as I’ve bought a 2018 G3 V6 Cayenne, how are these working out for you? Are there anything to look out for with the V6’s or for that matter V8’s or Hybrids?
Thanks in advance!
Thanks in advance!
With respect, you probably should have asked before you bought the vehicle? I'm getting my V8 in a couple months so I can comment on that then. Good luck
Hi Odin. This forum is for the 3rd Generation "9Y0" Cayennes. Your car is from the 2nd Generation of Cayennes, the 958, that's a separate forum here on Rennlist. iI you try your question in that forum I'm sure you'll you'll get more/better info https://rennlist.com/forums/cayenne-958-2011-2018-242/
Hi icemang. The 2018 Cayennes can be either 2nd or 3rd Generation, depending upon where you live. In the U.S. the 2nd Gen (958) sold through 2018.
The 9YO (E3) Cayenne was unveiled during August 2017 and first sold in Europe as a 2018 model. The rest of the world received it later as a 2019 model. OP lives in Norway, so I’m guessing it is a 9YO.
https://newsroom.porsche.com/en/prod...ion-14073.html
https://www.stuttcars.com/porsche-mo...-gen-research/
But I’ve heard about weaknesses in oil seepage between engine/gearbox on the 2nd gen diesels, rumors of bore scoring on V8’s and generally very complex trouble shooting on the hybrids, so asked the question to learn more about my new car model. I’ve had several Porsches and they’ve all had their issues. Are there anything to look out for with the 3rd gen Cayennes, and maybe in particular with the V6’s? Always eager to learn.
chassis (05-21-2022)
While I haven’t read about balance shaft (balancer assembly) problems on this site, the 3.0 and 2.9 have a 90 degree vee cylinder block which requires a balancer. 60 degree vee and inline blocks are more balanced for 6 cylinders, so the balancer is used to address the imbalance from the design shortcoming of the 90 degree V6.
Balance shafts have been problematic across years, manufactures and models. The MB M272 had balancer problems. No guarantee that the two Porsche engines will have a problem, but it is one design feature I don’t care for.
Odin (05-23-2022)
No gear box leaks as on the Gen2’s?
chassis (05-23-2022)
The Gen 2’s Aisin transmission has been replaced by the ZF 8HP. No issues (so far) with the transfer case problems that plagued the Aisin. Some folks report a rough 3-2 downshift with the ZF.
In fact, the Gen 3 is a major redesign — from new engines and transmissions to the chassis, which was completely redesigned from scratch. Read all about the changes in this press release titled “The Technology of the New Porsche Cayenne”
https://presskit.porsche.de/workshop...e-cayenne.html
jsun1818 (06-08-2022)
Hi Odin, the EA839 3.0T V6 is widely used in many applications across the VAG group. It’s been stout, with untouched bottom-end B9 S4 pushing over 500whp with bolt-on and running low 11s in the ¼ mile (granted its much lighter platform) With an upgraded factory location turbo and fueling it can be pushed even more without any major problems. The transmission is also very stout, but we don’t have any TCU tunes out for 9Y0 to my knowledge. I went 3.0 base over the 2.9 S because of the wide customer base of the 3.0 being used and abused and people finding very high limits, I hope this helps!
wutographydc (06-19-2022)
I have gotten up to 26 mpg, over an entire tank on some trips. City/Highway is normally 20 to 22 mpg average per-tank.
I found, too, that the oil/filter service, and engine air filter, on the 2.9L. is very straight forward and relatively easy, using a top oil vacuum extractor through the oil dipstick tube.
Having the oil filter at the top makes it a very clean process. The engine air filter comes out easily during the service process so it works great.
The following 2 users liked this post by PorscheACC:
chassis (06-11-2022),
The following 2 users liked this post by f10tt:
