Sponsored By:
Sponsored By:
Cayenne 3.0T JB4 - Wow, Mind blown
Old 11-04-2020, 06:15 AM
unskirted
unskirted's Avatar
Default Cayenne 3.0T JB4 - Wow, Mind blown
TLDR: Holy S***, I'm in love with this car all over again. Huge HP/TQ gains. Never thought, piggy backs can run this smoothly.
A little backstory - My overall past experience with the jb4 or any other piggybacks has never been very positive. I've had it on my m235i and f80 m3 and the unstable, inconsistent power delivery made the driving experience so terrible that I told myself that I'd never go piggyback again. Not only that, I never got that HP bump so many people praised about and assumed it was a placebo effect. Once I bought my 3.0T, I convinced myself for over a year that APR or similar shops will come out with a flash tune. After constant delays with no real promises of a flash tune, and knowing many of you are waiting for some sort of review, I decided to give JB4 one more shot. The hp/tq gains on s4/s5/sq5, etc seemed pretty promising, but I wasn't hoping for much since it hasn't been calibrated for the cayenne's.
I received the JB4 unit w/ bluetooth today and the install was much easier compared to BMW's. I would give it a 3/10 in terms of difficulty. All you need is a flat head and a 7mm wrench. Once installed and connected to the iOS app, the app detected the piggyback and updated the firmware automatically. I set the car to map 0 and let it idle for 10 min. I drove the car easily for a few miles until I felt that the ECU was smoothing out. I got on the freeway and decided to compare the maps on 3rd gear, 50 roll.
Map0: Stock tuning, disable JB4 - Even on map 0 the car does not feel the same. The TQ seemed to have increase drastically.
Map1: 2psi peak over stock (default) - Didn't even try this.
Map2: 3psi peak over stock - I thought, oh wow, there's a noticeable difference here. Pulled smoothly all the way up to redline and felt quicker than the Cayenne S.
Map3: 4psi peak over stock -Holy ****. I cant stop smiling. I'm not sure what it is, but the engine sounds much louder. The downshifts and acceleration is so dramatic, the sound of the turbo spools and diverter valve chirping makes the car so much more engaging. My buyers remorse for not going with a S or a Turbo is completely gone.
From a standstill, the cars eager to lunge forward. Still shocked with the difference. Overall, I can say firmly that I take everything negative back from burger tuning.
Edit: Now running map 5 @ 6.5psi. Pulling hard.
Here are the link's I used for the install.
https://burgertuning.com/products/jb...che-e3-cayenne
https://www.n54tech.com/forums/showthread.php?t=49608
https://www.n54tech.com/instructions...stallguide.pdf
https://rennlist.com/forums/cayenne-...-vw-ea839.html
File Type: csv
The following 2 users liked this post by unskirted:
BMS (12-03-2020), Jimmyk79 (09-30-2021)
Old 11-08-2020, 02:30 AM
bmw_e30
bmw_e30's Avatar
this is good news
Old 11-08-2020, 04:44 AM
unskirted
unskirted's Avatar
Also gained a bit of diverter valve sound (towards end of video").
File Type: mov
Old 11-09-2020, 11:48 AM
PTS
PTS's Avatar
Received 2,809 Likes on 1,282 Posts
I see Burger Tuning JB4 has 2 options for the Cayenne;
https://burgertuning.com/collections...che-e3-cayenne
https://burgertuning.com/collections...amera-jb4-beta
Is the first option specific to the 3.0 Cayenne?
Old 11-09-2020, 04:35 PM
unskirted
unskirted's Avatar
I have it linked but yes the one that says e3 cayenne (your first link).
Old 11-10-2020, 10:57 AM
Indiana Jones
Indiana Jones's Avatar
Now you're tempting me to go from an older GTS/Turbo to a new base! Bravo!
Old 11-10-2020, 11:37 AM
Pushinit
Pushinit's Avatar
I've also been considering one of the JB4 units and key for me is to be able to quickly remove if I want to. One thing that concerned me a bit was it looked fairly difficult to fish the connector through the grommet in the firewall to get to the throttle connector. How did you find that process to be? Was the grommet easy to find, puncture, and to fish through?
Old 11-10-2020, 02:01 PM
unskirted
unskirted's Avatar
Accessing the firewall was too much of a hassle, so I wired it between the fender and the door sill. I can take a photo if you'd like, but its a great fit and doesn't have any pressure points on the wires.
I'm also planning on visiting the dyno with some e85 in the tank.
Old 11-10-2020, 02:04 PM
Pushinit
Pushinit's Avatar
I was afraid of that. A picture would be very helpful, if you don't mind.
Old 11-10-2020, 08:01 PM
OCNYPORSCHE
OCNYPORSCHE's Avatar
I used a piggyback burger tuning on my BMW X5 diesel and it was great!
Old 11-10-2020, 10:32 PM
unskirted
unskirted's Avatar
It's very well hidden with doors closed.
Old 11-10-2020, 10:33 PM
unskirted
unskirted's Avatar
Hitting 18.9 psi on Map 3, where as I'm seeing 15psi max stock. Need to fill her up with e85 and try map 4/5 and dyno.
Old 11-11-2020, 12:18 AM
8378hjlafdljfads
8378hjlafdljfads's Avatar
This is so tacky, wth man?
Old 11-11-2020, 01:33 AM
NelsonLee
NelsonLee's Avatar
IMO having such a vital electrical wiring connection in an area with so much movement is a not a great idea ...
Old 11-11-2020, 02:13 AM
unskirted
unskirted's Avatar
Tacky??
Quick Reply: Cayenne 3.0T JB4 - Wow, Mind blown
