Sponsored By:
Sponsored By:
Parking Heater ?
Old Oct 31, 2016 | 03:27 PM
pierre_l's Avatar
pierre_l
Default Parking Heater ?
I am looking to add a parking heater to my cayenne hybrid, Porsche say they don't suply a kit and webasto also doesn't supply a kit.
Anyone know of the part numbers needed or another firm doing a parking heater?
regards,
pierre
Old Oct 31, 2016 | 03:44 PM
wrinkledpants's Avatar
wrinkledpants
I looked into retrofitting this, but it's a big job. It would have cost too much money for the benefit. You need fuel lines, different fuel pressure regulator, the control module, a different HVAC head unit, create the wiring harness, all the various clips and mounts, and and of course buying the webasto unit. I'm sure there are a number of other smaller parts that I'm not thinking of. Nobody makes a kit.
I ballparked about 5-7K total in parts and labor, but I'm sure it would end up being a lot more.
Old Nov 1, 2016 | 01:07 PM
thescratt's Avatar
thescratt
Newer hybrid or older one?
You could do this for the E-Hybrid..
http://www.suncoastparts.com/product/SKU958AUXCOOL.html
Old Nov 2, 2016 | 05:34 PM
pierre_l's Avatar
pierre_l
unfortunately older one! I ve heard that it is very easy for the new one
@wrinkledpants: as for the part list, would you mind sharing it with me? I d like to see whether I can find some parts used
Old Nov 15, 2016 | 09:35 AM
user 83838290's Avatar
user 83838290
In case someone wants to know how it looks like and what parts are installed. Just got a 957 TT pig in w/ parking heater option.
It should be pretty easy by the looks of it, just need a couple of Ts and a 3 way valve to retrofit. Make it a standalone system w/ timer or remote and voila.
Old Nov 15, 2016 | 09:37 AM
user 83838290
As for me, I'd just do an engine preheat. This way you'd start with a warm engine that blows hot air from HVAC right after start. I'd ditch the HVAC system control or maybe just hardwire it to turn on "stupidly" for a preset period of time as the water will be circulated and heated up anyways.
It's still a 2k in parts investment but better than 7k
Old Nov 16, 2016 | 03:02 AM
RS-America's Avatar
RS-America
We went last winter up to Coldfoot, AK with our Cayenne diesel. Only thing we added was a 110v heat pad for the oil pan, never got to use it. Overnight at one place where temps got down to -36F, cold-soaked our diesel started right up with no more clatter then usual. It was so cold a newer Cummings Dodge serpentine belt broke upon start-up.
We looked into a Webasto heater which we could have gotten. Issue is to get our North American ECU to recognize the heater to turn it on.
Old Nov 16, 2016 | 06:41 PM
BIG smoke's Avatar
BIG smoke
Sounds like an expensive retrofit.
For my cars and trucks in the cold.
Good battery, maybe a heated battery blanket.
Block heater, and the right oil.
My old ford explorer would fire right up with 0-15 weight oil in the winter at -4o.
RS-A Up to Coldfoot? That is north...
