Interior alarm active after unlocking using remote
This just started the other day on my 2011 S. When I unlock the car using the remote the interior alarm stays active and goes off when I open the door. If I unlock all the doors using a double-push the interior alarm shuts off and I can open the door with not problems.
I verified this today by watching the indicator LED on the door while standing next to it. A single push unlocked the door and the light changed to a slow blink. Re-lock it and do double-push and the light goes out.
I checked the durametric and not faults other and the CAN BUS (1538/602 & 1539/603) but checking previously no one knew what they were. I had them a long time ago and cleared them and they weren't there a week ago but since this is new I don't think they are related.
Anybody have suggestions on what to check next?
Are there any stored codes right now?
If so - what module?
Certainly if there are communications problems in the CAN-BUS network it might cause problems such as your vehicle exhibits.
The errors listed were the only thing that showed up. But as mentioned, they were there nearly a year ago right after I pulled the head unit to have it repaired. I cleared them and they haven't shown back up until just now. Back then I figured it was because the head unit was out of the vehicle and the bus was in an "open" state. While the timing is a bit odd I don't believe it's connected with the alarm issue.
No other codes/faults were reported when running the Durametric short test and I cleared all the faults last night.
ETA: I just reran the Durametric short test after driving in to work and there were no failures. However when unlocking the car the interior alarm stays active with only a single press of the remote. A double press unlocks all doors and turns off the alarm. This is based on observing the indicator in the door.
Interesting. I wonder if Durametric has the ability to show the current state of the modules? I'd have to hook mine up to see (I've mostly been playing with the ICarScan - which has the ability to read real-time data.)
It sounds as if you have the lock system setup to unlock the drivers door with one push, and all doors with two pushes (that is an option.. under vehicle settings.) Can you change to all-doors with one push and see what happens?
I actually did just set it to open all doors today at lunch and it unlocks and disables the alarm just fine. I then reset it back to unlock the driver's door and the alarm stays active until the 2nd push.
My Durametric is not able to read the door module for some reason (never has so that isn't new) so I'm guessing there's an error there someplace. At least I've got a workaround for now.
I'll have to see what the ICarScan can read from that module, provided I can figure out what module it is (each door has a module..) I'll start with the driver's door.
Will let'cha know what I find.
Tom,
Just took a look. The only mention of the security system is in the door modules, and the "rear" module (whatever that is..)
Here is what I can read from the door modules (data stream):
=====2016-04-12 16:27:58=====
Key button up No
Key button down No
Lock secured feedback No
'Lock safe' feedback No
Rotary latch microswitch open No
Rotary latch No
Door inner handle No
Outer door handle actuated No
The values change if I play with the parts being reported on. There is a function available in ICarScan to actuate the door locks.. but I didn't try that. Also in the Gateway module I can turn the alarm warning LED on or off.
Totally puzzled on where to look for your problem.
Does it do this with both keys?
Does it do this if you open/unlock the vehicle with the door handle?
Key button up No
Key button down No
Rotary latch No
Looked on AllData - it appears the alarm function is built into the rear-module.
#1 is referred to as the rear module. This photo is from a rather long sequence about adding a diode in-line to the rear module for some reason involving the alarm. Unfortunately they didn't elaborate on the reason.
Also: http://uedata.amazon.com/Launch-Tech...emL&dpSrc=sims - cheaper but you have to pay for any car brand..
Took a look on Amazon - ICarScan still available. All from Hong Kong - but I had mine 2 days after I ordered it - faster then from a US vendor. http://uedata.amazon.com/s/ref=nb_sb...words=icarscan
BTW - from what I saw in AllData - you might try looking at the rear-module. I haven't explored this yet with ICarScan, but the stuff in AllData implied that's where the central unit for the alarm system is located.
Just experienced the same issue as Tom M with my 2011 Cayenne alarm. My alarm goes off despite unlocking the driver's door.
Used the key fob to unlock the door. For some reason, despite the driver door unlocking, the alarm goes off (Alarm light still blinking). So not sure if it is still sensing the interior motion alarm. Tried bypassing the motion sensor by pushing the interior doorjamb bypass button but that did not work.
So, I did the same thing Tom M did. I went to "settings" and set the keyfob button to open "All doors" rather than just the driver door. This seems to work as a work around.
I hope this is not the initial symptom of the alarm module failure due to the built in battery. We shall see. Lots of gremlins as our Porsches age and mature.
