dash top chrono/clock harness
#106
good can someone pass me the electrical diagram of the picture of this same bcm car and the contact key? I dedicate myself to the repair of modules and I need to try it on a table is possible ?? Thanks for the help
#108
Clock Light Activation.
https://rennlist.com/forums/cayenne-...ble-again.html
I can't speak about other brand diagnostic computers since I haven't had them to play with. I'm sure the computer (PIWIS) the Porsche dealer has is capable of doing this.
i would appreciate your usual support providing me with how to do the clock enabling step by step using iCarScan.
#109
can anybody please help me to get the time - chrono option since i have followed this procedure and still i don't have this option and the clock back light is not working as well. Also, i tried to reprogram the car using PIWIS but unfortunately the back light works only during test.
can any one help me how to get it done please.
#110
Just got to doing this wiring today. Have had the clock sitting inside the panel dead for about 2 weeks now.
Anyway, first off.... thank you to everyone who put effort in describing wires and the cayman harness. Also, the wires to which to tap into.
I ended up reusing the rest of the wires from the cayman harness to extend the wires. Then the porsche cloth loom to cover them nicely. Also, I opted to cut, strip, solder and shrink all my connections. Then closed it all up in the same cloth loom.
Lastly... I powered ignition, turned off ignition, took out key, turned on ignition again and the clock was recognized. No coding needed. The backlight is a bit low, but maybe that's how it is. I can clearly see the arrows.
Adding some pics for fun. But i think this should be a DIY sticky. I can write one up if it will get its place in DIY section. LMK .
#111
Received 1,160 Likes
When I first installed mine - it worked - but didn't really light up. I found a setting I could change either in the PCM menu, or more likely in an iCarScan menu, probably under the instrument cluster.
It would be great to have a DIY - but a bit more info is needed in your posting to qualify, and some editing:
1. Photos shouldn't be more than 1024 pixels wide. Resizing is a good thing.
2. There should be a caption or header for each photo so we know what we're looking at.
3. There should be some text saying "Then I did XYZ with this result.." sort of thing. Best added to photos illustrating doing XYZ..
4. Tools needed and sources for the materials used (clock, the clock mount, the wiring harness in particular..)
Would love to see a DIY that could be copied over to the DIY subforum.
#112
#114
#115
#116
Thanks!
#119
Where did you sing the dash trim? Hope you didnt buy new..... I paid all of $30
#120
