Yes another A/C blower motor thread
2011 CTT - Unable to get the answer elsewhere
Is it possible that an intermittent blower motor causes lack of cooling (even when it actually comes on and with fully controllable fan speed)?
Thanks in advance
Thanks in advance
I sort of don't understand the question..how is it intermittent if it comes on and your fan speed is fully controllable?
I always used the test where you manually turn the fan up and down one notch at a time and you should be able to feel and hear a difference at each level. When I lost my blower motor, everything above the bottom 3 levels was the same, so I knew it was time to replace.
CAVU (08-08-2024)
Yes it seems that the compressor pulley is turning (but I'm not sure if that's a clutch - my understanding is that there is no clutch on these, and that a regulating valve controls refrigerant flow). As for the evaporator outlet pipe, is it possible to access it without removing the center dash? would it be on the passenger or driver side?
Have someone start car and you stand looking in to the engine and watch to see if the compressor changes in sound and pulley movement. You can see it engage and disengage. Oh, yes, the person in the driver's seat would be turning the AC on and off.
That doesn't make sense. Had to have a clutch or the compressor would be running when the engine is was running. That would mean there would be no difference in power or MPG whether you were running ac or not.
Because my problem started in the middle of a heavy rainstorm (And yes I checked/cleaned all the drains), I'm inclined to believe that it's an electrical problem that is preventing the refrigerant from circulating. A faulty (usually totally broken) blower does that, because of the feedback loop to the electronics through it's speed regulator....but it's also puzzling that the blower is actually now back to working with all the speed controls and yet no cold air. Wondering if it's plausible that the circuitry within the blower regulator can still be the culprit - and hence my question in the first message. I just hate to just throw new parts on the problem without further confidence on it, based on others' experiences
On this forum, I have read of more blower motor issues than refrigerant/compressor system issues.
My blower motor gave out at 8 years. https://rennlist.com/forums/cayenne-...acement-2.html
Near the end of the thread you will see some photos of my tear down of the bad motor. There is not just a resistor pack in there.
Check all of you HVAC related fuses.
Another thing to check, while I go outside and check out my compressor and how it works.
The temp sensor is integrated in the dashboard and must not be covered or taped over.
Thanks for the note. My temp sensor is definitely not covered. There are other temp sensors in the ducting going from the output of the blower, such as just before entering the cabin filter, and at the side vent. They're identical and interchangeable sensors. I tested those at room temperature and in the refrigerator, with changing resistance as expected.
here is a easy thing to try. disconnect the ground cable in the driver's footwell for about 30 minutes. That will provide a hard reboot to all of the modules/computers in the car. Every once in a while, it solves a problem.
OBTW, what part of the world is this car?
Thanks again
Same happened to me- blower motor would come on intermittently. Either full air on none. Changed blower motor (1hr job). all good. As for your AC issue, i would change the blower motor first.
