DIESEL - Transfer case fluid
What’s everyone using for transfer case fluid on their DIESEL transfer cases? There are hundreds of posts about the standard transfer case fluids and additives, but little on the Diesel boxes which are an entirely different unit. My only findings so far are the oem Porsche / VAG fluids.
Thanks!
Thanks!
I’ve been trying to figure that out for a few days now..
See my posts at the end of this thread:
https://rennlist.com/forums/cayenne-...id-change.html
In the thread garret376 posted:
I guess I’ll be buying 3liters of 75w-90 tomorrow
@aututto, small favor, can you edit your original post and remove the DTF-1/TF-0870 reference. Lots of people read the forums and without reading the whole thread may end up with the wrong fluid for their V6 or Diesel Cayennes.
Just to set the record straight:
- Cayenne V6 3.0T Hybrid and Diesel use straight synthetic 75w-90 gear oil in their transfer cases. I'm a fan of Valvoline for the gear oils.
- Cayenne Base V6 (3.6) S/Turbo, V8 and Turbo use the fancy DTF-1/TF-0870 fluid in their transfer cases.
The following 2 users liked this post by AnAlbumCover:
AbominableR (01-24-2024),
BrewDude (08-27-2023)
Thanks for the replies. I won’t start the which 75w90 is best as that is about like a Coke vs Pepsi discussion. I generally have used Redline gear oil in all the other toys, but it seems Ravenel is pretty popular with the Porsche crowd.
