Sponsored By:
Sponsored By:
Coolant leak below intake manifold - Diesel
Old 02-03-2022, 07:46 PM
Sudar
Sudar's Avatar
Originally Posted by ChrisTDI
I would image it looks like that. I personally havent seen the car since it entered the dealer. There are many plastic pieces that are between the intake manifold and the engine that can crack.
This is interesting, did you maintain the car at the dealer as well? I was denied goodwill, but never had them check out anything other than warranty repairs. Thinking of going to a different dealer for my next purchase because of that.
no, it was actually the 2nd time I brought the car to this dealer. 1st time was warranty work, and coolant started to leak next day after I picked up the car. They said they haven't touched anything and only worked on exhaust, so must've been a coincidence
Old 02-08-2022, 02:55 PM
wm711
wm711's Avatar
I just last week go the low coolant level message. I can smell the coolant as well, more strongly from the passenger side. 2014 83000 miles. CPO expired 12-2-2021. Let the games begin...
Old 02-09-2022, 04:19 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,568 Likes on 1,598 Posts
Originally Posted by Diesel4Life
North Houston Porsche covered this for us at around 86,000 miles under the Diesel warranty
Now you made me mad, because they didn't cover it for me. I tried to get Chris to see if it was covered and he said it wasn't part of the extended diesel warranty. I believe it was the EGR cooler.
Old 02-09-2022, 04:24 PM
Needsdecaf
Needsdecaf's Avatar
Here was my post of what was replaced.
https://rennlist.com/forums/cayenne-...l#post16483562
Old 02-11-2022, 03:46 PM
ChrisTDI
ChrisTDI's Avatar
Just to update everyone, I paid for the repair out of pocket. PCNA and the dealer had a pretty firm stance that the repair was not covered under the Diesel Extended. And it was about $1800 out the door.
In the conversations with PCNA, I had them provide exact part clarification what the Diesel Extended covered.
Take it as you will, this is just a guideline from them:
Thank you for contacting Porsche Cars North America regarding your Cayenne Diesel Emission Warranty. Per our conversation, you requested to see what is covered under your extended warranty. Down below I have listed what is covered under your warranty.
Basic engine
Crankcase
Lid
Crankcase cover
Piston
Piston-ring set
Con-rod bearing
Connecting rod
Crankshaft
Crankshaft bearing
Drive wheel for balance shaft
Balance shaft
Camshaft
Camshaft bearing
Camshaft sealing ring
Toothed belt for camshaft
Toothed-belt tensioning roller
Chain housing cover
Sprocket
Control chain
Hydraulic valve for camshaft controller
Tension rail
Guide rail
Rocker arm
Valve lifter
Inlet valve
Valve
Exhaust valve
Cylinder head
Cylinder head gasket
Cylinder head cover
Oil pressure switch
Oil level sensor
Oil pump
Pressure-regulating valve
Oil guide housing
Oil pan
Temperature sender
Fuel tank
Fuel pump
Fuel pump control unit
Accelerator pedal
Intake pipe
Turbocharger
Moulded hose
Pressure pipe
Charge air cooler
Exhaust temperature sensor
El. adjuster for turbocharger
Pressure sensor
Fuel pressure sensor
Solenoid valve
Injector valve
Fuel distributor
Throttle body
Mass air flow
Intake distributor
Temperature sensor
High-pressure pump
Electronic adjuster for intake manifold flap
Oxygen sensor upstream of catalytic converter
DME control unit
Power-supply relay
Fuel line
Exhaust system
Exhaust system
Loudspeakers for exterior acoustics
Exhaust gas post-treatment
Pipe for CO check
Control unit for acoustic simulator
Pulse sender for interior acoustics
Exhaust manifold seal
Exhaust manifold
Deflector plate
Cover plate on exh. manifold
Heat shield
Heat shield
Seal for front exhaust pipe
Front exhaust pipe
Differential pressure sensor for particle filter
Heat shield for exhaust pipe, front
2621
Clamp
Heat shield for centre exhaust pipe
Front muffler
Connector tube, rear
Front exhaust-system mount
Exhaust system mount, rear
Intermediate muffler
Clamp seal
Rear muffler
Tailpipe
Tailpipe trim
Change-over valve for exhaust system
Centre exhaust system mount
Exhaust gas recirculation valve
Vacuum line
Exhaust gas recirculation cooler
Switch-over valve
Vacuum reservoir
Exhaust gas recirc. line
Distributor housing
Exhaust gas pressure sensor
Actuator for exhaust flap
Thermo valve for exhaust gas recirculation
Secondary air pump relay
Vacuum check valve
Secondary air injection
Control valve
Belt for secondary-air pump
Secondary air pump
Pressure hose
Line for air injection
Check valve
Shut-off valve
Air cleaner for air injection system
Catalytic converter
Particle filter
Air injector valve
Primary catalytic converter
Reducing agent tank
Reducing agent tank sensor
Reducing agent metering pump
Catalytic converter indicator light relay
Air pump holder
Heating element for reducing agent
Residual soot sensor with control unit
Reducing agent supply line
Reducing agent injection valve
Control unit for reducing agent
DeNox catalytic converter
Reducing agent
EX-light
NOx sensor
Catalytic converter heater control unit
Heating element f. catalytic converter
Hall sender
Pulse sender
Glow plug
Glow control unit
Transmission electronics control unit
Speed sensor front
Hydraulic unit
Brake booster vacuum pump
Instrument cluster
Time management control unit
Gateway control unit
Outside-temperature sensor
Stop light switch
Vehicle e. sys. ctrl. unit
Engine wire harness
Old 02-14-2022, 11:54 AM
vwbrd
vwbrd's Avatar
Watching this thread with interest. I think I can detect a faint whiff of coolant when I park in the garage after driving, but the level is between min and max and I don't see the fittings suggested weeping. Plan to ask my indy at my next oil change this week if they see anything.
Carboncrew (04-30-2023)
Old 02-14-2022, 12:40 PM
ChrisTDI
ChrisTDI's Avatar
I highly recommend looking at it asap if you still have a warranty and smell coolant.
Old 02-14-2022, 01:19 PM
vwbrd
vwbrd's Avatar
I'm at 119,9xx
have never been able to verify if I still have coverage or not.
Old 02-14-2022, 01:25 PM
ChrisTDI
ChrisTDI's Avatar
I'm at 119,9xx
Call Porsche cars north america if you are in the USA
Old 02-14-2022, 01:51 PM
dollarlongnecks
dollarlongnecks's Avatar
There are two concurrent warranties. One is more comprehensive than the other:
Extended Emissions Warranty Information:
The vehicle has an Extended Emissions Warranty that runs for 10 years or 120,000 miles from the original in-service date. Please see your Porsche Dealer for additional information including the vehicle’s in-service date.
In addition, and concurrently, the Extended Emissions Warranty runs for 4 years or 48,000 miles (whichever occurs first) from the date of modification or first dealer resale post-modification.
For me, looks like I just exited the golden ticket warranty in November - Your vehicle was modified on 2017-11-16 and 96918 miles. Please see your Porsche Dealer for additional information on the vehicle's post-modification dealer re-sale date.
I had to go back and check as I thought I had some coverage through 2023, but looks like the mileage is too much.
You can check your own vehicle here: https://www.porschediesellookup.com/...ReadForm&c=usa
Old 02-15-2022, 11:27 AM
vwbrd
vwbrd's Avatar
Well, I got it in the shop today at 119,999 We'll see what they say, but I expect them to tell me I'm imagining things.
Old 02-18-2022, 10:55 AM
d7101
d7101's Avatar
I have both the 4 and 10 year warranty still running on my 2014 CD and was just quoted $5700 (canadian) for this fix. Needless to say i am floored by the cost and asking for more details. Have been told warranty does not apply
Should i be escalating to Porsche Canada?
Old 02-18-2022, 11:07 AM
ChrisTDI
ChrisTDI's Avatar
Its up to you, but doubtful Porsche Canada would be able to do anything since this is outside of the warrantied items. Honestly, it might be work calling an independent shop for that kind of money. I paid 1800 usd and they gave me a loaner for 2 weeks.
Old 02-18-2022, 11:28 AM
d7101
d7101's Avatar
I'm honestly thinking i might just take it back and keep topping up the coolant at this point. Does this issue eventually get worse? or is this something i can potentially live with?
Old 02-19-2022, 07:04 AM
dollarlongnecks
That price seems crazy, as mine was around $1800 usd as well. Maybe find another dealer or an indy.
Quick Reply: Coolant leak below intake manifold - Diesel
