2013 CD and EGR cooler issue. in the shop
From the other threads, it seems like it's at the oil cooler control valve.
Originally Posted by Needsdecaf
ill share the part number, but it’s not a warranty repair. Unfortunately.
The 'Governor' is the main culprit...
Originally Posted by MajorPain
Dieselgate because ours is not CPO
Originally Posted by dollarlongnecks
You still have less than 100K on the vehicle, correct?
I think the extended warranty us expanded a bit at lower miles, as I remember I lost some warranty coverage once I passed 100K.
I've seen a lot of comments about dealerships not wanting to cover some things, and I have to say I'm confused by it all... Was the warranty given to people different if they owned the vehicles when the fix happened, vs purchasing after the fix was applied?
I know for a fact that the crappy dealership I was going to at the time would not have been doing me any favors, so they were obviously getting reimbursed by Porsche on the repairs they did, so I don't know if something changed since then, or there are variations on the warranty giver to customers, but it seems odd that I was getting this extra warranty when others weren't (or aren't currently).
^ Maybe someone else can comment on dealership double dipping charging customers and filing for warranty reimbursement. I don't know. I do know that sometimes dealerships don't get reimbursed for what they thought is work .
OK, so when the whole Dieselgate thing first happened, they were treating all affected vehicles like a CPO - it wasn't actually a CPO, but the warranty coverage they offered was basically a mirror of the CPO... During this time I had ~85K miles, and was getting all sorts of things fixed - The PCM was replaced, they fixed some squeaks/rattles, several oil leaks - basically everything that was done to the vehicle was covered under the warranty... Then at 100K the 'CPO'' part went away and all that remains is the extended emissions warranty that is supposed to cover anything that could potentially be impacted by the fix - so all the emissions stuff, and almost everything that connects to those parts.
Because my part above is part of the oil cooler, not the EGR cooler, it was not covered under warranty.
