Sponsored By:
Sponsored By:
18 way seat gremlin
Old May 22, 2019 | 03:14 PM
gekko997's Avatar
gekko997
Default 18 way seat gremlin
Upon acceleration or braking, I will sometimes feel a slight movement or shift in my driver seat. It is subtle and does not always happen. They are the 18 way version and I like them; however, the driver's seat feels like it wants to become a 20 way seat and I would prefer this stay 18 and under. I read something about just adding a simple washer to a bolt and this issue was resolved on 997s.
Has anyone here experienced this on the cayenne?
Old May 23, 2019 | 04:54 AM
deilenberger's Avatar
deilenberger
First time I've heard of it on any Cayenne. Sounds like a bushing is worn somewhere. If the battery has ever been changed it might be worth checking the bolts that hold the seat-rails to the floor are tight. Certainly other cars are known for this sort of thing (BMW M-Coupes for instance.. I had 2 of them, they both did it unless I lowered the seat to the lowest position.)
Old May 23, 2019 | 09:24 PM
Tim Wasmer's Avatar
Tim Wasmer
I have the same thing with my 18 ways. I thought a bolt may be loose so I tightened them and they were snug. ALMOST feels like something is loose int back rest of the seat.
Old May 28, 2019 | 10:11 AM
gekko997's Avatar
gekko997
I read about someone having this issue with their 997, where the underside of the bolt had some minimal wear which caused the play in their seat - fix / solution being placing a washer underneath the bolt. I have not yet had an opportunity to take a look at my seat, but will hopefully in next week or two. I will post an update if I get this figured out.
Old Aug 11, 2020 | 01:20 PM
PhilT3 (PT3)'s Avatar
PhilT3 (PT3)
you guys ever get this figured out? I gave the same issue in my 16 Turbo S 8th the 18-ways.
Old Aug 11, 2020 | 01:21 PM
PhilT3 (PT3)
you ever get this resolved?
Old Jul 28, 2023 | 07:49 PM
Snowtoy16's Avatar
Snowtoy16
Cruisin'
Default Seat shimmy
Has anyone solved the issue?
Old Aug 12, 2025 | 12:01 PM
TomF's Avatar
TomF
Okay... I have the same symptoms in both my 14-way seats. It is a bit unsettling. On acceration or braking there is about two or three milimeters of movement of rocking (not sliding) on the axis of the car. The whole seat is moving- it appears to be someing related to the mounts. Did anyone find a solution to this issue before I do a deep dive and try to solve it?
Old Jun 1, 2026 | 07:06 PM
TomF's Avatar
TomF
Just got back from the dealer for some warranty work, including the seat issue. They can duplicate the problem in both seats, but now want to charge me a 1/2 hour of labor to investigate. I will dig into it and see what I find out.
Incidentally, they do not warranty rattles after three month after delivery... This is news to me. Huh?
