Sponsored By:
Sponsored By:
Error P059800 Thermostat issues
Old Nov 1, 2024 | 02:59 PM
Kaïzer Söze's Avatar
Kaïzer Söze
Default Error P059800 Thermostat issues
The code reads: P059800 Thermostat for Map-controlled engine cooling, Short circuit to ground. And in a blue bubble under the code it says “No Fault Symptom”
Is is my third thermostat housing and thermostat so I’m guessing the issue is either the connection or the harness. Am I right to think that the wires that go to the thermostat have grounded somewhere in the engine valley or elswhere?
Any other ideas?
Old Jun 1, 2026 | 04:29 PM
Ego's Avatar
Ego
4th Gear
Default Re
Any other ideas?
Did you ever figure out the issue with the P059800? Im having the same issue and can't find any info that is useful.
Old Jun 1, 2026 | 04:52 PM
Kaïzer Söze
I replaced the housing and thermostat and housing. I was tired of chasing my tail.
good luck
Old Jun 1, 2026 | 06:59 PM
Ego's Avatar
Ego
4th Gear
good luck
Did you replace the oil filter housing with the oem mahle? Did the P059800 go away after replacement?
Old Jun 1, 2026 | 07:09 PM
Kaïzer Söze
Yes. I replaced the whole housing which incorporates the oil filter housing.
Old Jun 1, 2026 | 07:28 PM
Ego's Avatar
Ego
4th Gear
Thats great information. Thanks!!
