Air Filter
Air Filter
Is the Mahle Lx2024 filter the same as the Porsche OEM 958 110 130 00? The Mahle is half the price of OEM on amazon. Just want to make sure I am getting oem quality. The oem is $15 less on amazon than the dealer.
Mahle is an OEM supplier to Porsche so you should be good to go. Pelican Parts also shows two different Mahle filters (heavy duty & standard) but the pictures are the same for both items. Either way, unless you are in a severe environment the standard filter will be good. Personally, I've used both Mahle and Mann filters depending on the prices at the time.
Mahle
Mann
OEM
I use all three and they are all pretty much the same
Mann
OEM
Received 1,160 Likes
Just changed my filters out today and went ahead and left the foam in place, figuring the additional filtration might be better for the motor (with maybe a sliver less power). Will see if I notice any difference in mileage or the butt-dyno. :-)
^^That gives me an idea.
I stopped using K&N filters long time ago when it was proven that they allow more dirt to pass through than an OEM filter. I wonder if I took a pair of K&N filters and placed a piece of foam on the intake side of the filter. Might help with the dirt and both are totally washable.
Buy an Afe and never worry again.
https://afepower.com/afe-power-31-10...y-s-air-filter
Reusable, washable, and doesn't need to be coated in oil for filtration. Peace of mind for your MAF.
