CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#1187
Hi, sometimes I like to listen to radio and have waze on. To do so, I need to switch to FM and loose AUX input. However, if I am receiving a call, I cannot hear anything because I am not on AUX obviously. Is there a trick to have everything to work smoothly in that case? I have remove all the Bluetooth/phone connection to the pcm...
Is there any solution to this?
Thanx
Thanx
The only issue that this creates is that if you have PCM BT connection on, and you have steering wheel controls, when you receive a call and press the steering wheel control phone button, then the call goes into hold, and then you’ll need to press it again. The work around, press the steering wheel “enter” button on the right. Or just press the phone button on the PCM (which do not have this issue).
#1188
Yes here : https://www.ebay.com/itm/223585992852?ul_noapp=true
But I will return JoyeAuto and buy other brand (Sinairyu) with reinforced cable and different more "natural" cable management to avoid internal problems.
Forward - reverse ? how many pins ? thx
#1190
There is a ribbon cable that has to fold the right way when reassembling the pcm unit. Sometimes it folds the wrong way and blocks the CD from being ejected. You can either open the unit and readjust or use a thin flat plastic tool like a disposable plastic knife and wriggle it gently the full length of the CD slot and nudge the cable up in case you detect an obstruction..
#1192
I had no idea you could predict things. I was chatting with my wife about how I was unable to remove the CDs and she presses the eject button, out came the CD. So we ejected all 5 of them and so far so good, at least until the last CD. Then everything went south The PCM showed an error message regarding mechanical drive failure, and then the screen went blank. I restarted the PCM and now I have a hazy screen and can't read anything on the screen. Radio works, but it looks like the screen cable is gone?! I'm now looking to get two or three sets of these cables, so where can I buy those? Never thought I'll have to re-open the PCM again sigh!!
#1193
Wow, bad luck man !
Someone’ posted this eBay link a while back……it seems if we can figure out the specs…..you can get them cheap.
I do not know of anyone who has ordered these replacements yet.
https://www.ebay.com/itm/333808583318
#1194
Wow, bad luck man !
#1195
I’ll bet that you pinched the ribbon cable…..between the cd slot inside and the main pcm chassis …….and that it has dislodged a ribbon inside the PCM. I think you will be fine with new cables, and clear routing.
You could take it apart…and may be able to fix it……. But having new ribbons on hand would be good.
EDIT: just realized your PCM3.1 is different to mine ……mine only holds 1 CD. None the less….it’s a cabling problem I bet.
#1196
#1197
#1199
Oh wow! You're good. I also reached out to other sellers on Amazon, hopefully someone will reply.
